won't go into park
Transmission: A4
Re: won't go into park
check the linkage under the car on the tranny. I had a problem like this a LONG time ago and it was 2 loose bolts or something IIRC. It was over 12 years so my memory is a little bad. also look inside the console and see if something is jammed inthere stopping the shifter from going into park. These are the FREE things you can do before it goes to a shop. if you cant find the problem then dont worry. if it shifts fine then just put it in N when its off and use the E brake. Run it like that until it gets worse and then go from there
Car: 1988 sport coupe
Engine: 2.8
Transmission: 700 r4
that makes since, thanks. I didn't think of that.
hey, 86
What did you do to fix the problem?
hey, 86
Car: 86 IROC-Z
Engine: 305 V8 carb'd
My cable had broke so I bought a new one & replaced it. Once I I got it in it wouldn't go into park. The cable has a rubber type ring on it that mounts onto a metal plate on the left of the shifter & that piece was not pushed all the way in. Once I fixed that it went into park just fine.
///DAN///
Sep 25, 2015 02:15 PM
