Rubbing noise
Old Sep 4, 2007 | 09:11 AM
mynew5spd's Avatar
Car: 1983 Z28
Engine: 305 - LG4
Transmission: 5spd
Rubbing noise
Wondering if anyone can help identify the source of this rubbing noise.
When I start the car cold the rubbing noise will be very strong. After a minute or so it will slowly fade away. I could almost swear the sound is coming from right under the gear shifter. The rubbing sound is in sync with engine speed (rpm's). After the rubbing initially fades and I begin to drive, within a few minutes it's back in all forward gears (haven't tried reverse). No matter if the clutch is engaged or not, it's there. While driving, the rubbing is soft or strong depending on what gear I'm in and engine speed.
When the car is stopped (at a light or parked in neutral) the rubbing will slowly fade away after a minute or so only to re-appear when the car is put back in gear and engine speed increased.
I'm almost positive it's coming from the area under the gear shifter as I think I can feel the rubbing while holding the shifter ****.
Anyone know what this might be?
Thanks!
Old Sep 7, 2007 | 04:02 PM
mynew5spd's Avatar
Car: 1983 Z28
Engine: 305 - LG4
Transmission: 5spd
Re: Rubbing noise
Ok, sounds more like a knock than a rub. Definitely not coming from the engine.
Old Sep 7, 2007 | 04:56 PM
Re: Rubbing noise
It's probably the whirring noise of all the bearings and gears and whatnot in there, all spinning around.
Does it slow down & stop when you push the clutch in? Stop immediately if you put it in gear?
db057
Jan 10, 2020 08:55 PM
MrPackstin
Oct 25, 2017 08:09 PM
sleprock
Interior Parts Wanted
Oct 3, 2015 11:01 PM
sjorgens
Oct 1, 2015 07:54 PM
Randomtask2
Sep 7, 2015 05:06 PM
