Posi swap?
Old Jul 14, 2003 | 07:48 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
Posi swap?
I have the posi and axles out of an 87 camaro with 2.73 gears and drum brakes. I want to swap the posi into my 82 Z28 camaro with open 3.73 gears anddrum brakes. What is involved? Can i just take out the differential out of my car and just throw in the posi? Do i have to use the 87 axles? Is it even possible, or do i have to have the rear "setup" again?
THanks
Old Jul 14, 2003 | 07:54 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
You need a ring gear spacer, to put the 3-series gear onto the 2-series carrier. You don't need a gear setup in all likelihood; check the backlash to be sure. The pinion won't need to be disturbed in any case.
Splines and axles are the same. Use the best axles out of the 4 (all 4 are the same).
That, and about 2 quarts of fluid and one thing of additive, should about do it. I'd recommend putting new axle bearings and seals in it while you have it apart.
Old Jul 15, 2003 | 06:44 PM
ME Leigh's Avatar
Car: 82 Z28
Transmission: TH350
Great thats exactly what i want to know. So the axles are the same, awesome!!! Now where can i find this ring gear spacer?
Old Jul 15, 2003 | 07:50 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
RingGearSpacers'R'Us.
http://www.drivetrainspecialists.com...=28&cat=GM+7.5 IK83-0750
I post this URL so often, these guys should pay me a commission :sillylol:
Old Apr 30, 2004 | 10:55 PM
ME Leigh's Avatar
Car: 82 Z28
Transmission: TH350
Do you know any part numbers for the ring spacer. I want to try and get it locally if i can. Can order it at napa or schucks; or do i have see a driveline specialist?
Old May 1, 2004 | 07:53 AM
Ricktpi's Avatar
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Axle/Gears: Moser 9"/4.11 Trac-Lok
I ordered one from the local speed shop a few years ago. It was about $50 then (1999). They probably got it it from DTS.
Old Sep 5, 2007 | 01:07 PM
87z28ss's Avatar
Re: Posi swap?
hello . i have the 2.73 open i believe . LG4 . i want to make it a posi and put in 3.42 or 3.73. what all do i need >> ?? any help will be appreciated .
thanks !!
Old Sep 7, 2007 | 05:14 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Re: Posi swap?
Why would you revive a 4 year old thread for a new question?
You will need a 3 series posi, and the gears. Also a full rebuild kit, which includes shims, crush sleeve, bearings, and seals.
Old Sep 7, 2007 | 06:01 PM
Tobias05's Avatar
Car: 1987 Camaro SC, 1999 Z28
Engine: GMPP 350HO, LS1
Re: Posi swap?
at least he used the search, gotta give him that.
IroczFan
Oct 6, 2015 10:13 AM
hectre13
Aug 26, 2015 08:17 AM
mcgarnicle
Aug 12, 2015 04:58 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
