T-5 trouble
Old Sep 5, 2007 | 10:59 PM
burnt_rubber's Avatar
Car: 1985 Camaro
Transmission: 5 speed
T-5 trouble
A few months ago my tranny went and i got a used tranny from the guy i bought my car from. He sold it to me for $350. When i got er in my car it wouldnt stay in first gear. I would put it in 1st and when i let go of the clutch it would grind and pop out. Would this be the syncro? He says hes getting another t-5 he picked up but hes busy with harvest right now. so if he doesnt get this other tranny can u get a machine shop or a transmission shop to fix the it? and how much would it cost apprx?
Old Sep 6, 2007 | 05:42 PM
86irocu's Avatar
Car: 1986 Iroc-Z
Axle/Gears: 3.73 posi
Re: T-5 trouble
mine has the same problem.. and my new clutch is slipping already... it only have about 1,000 miles on it... But mine is a bitch when it pops out. I'm gonna take it to a tranny shop when i get a chance.
Old Sep 6, 2007 | 05:52 PM
327_TPI_77_Maro's Avatar
Car: 2000 BMW M5
Re: T-5 trouble
Yes. Popping out of gear means the locks in the syncrho hub are probably broken. Total rebuild time. Rebuilding a T5 yourself is about as easy as rebuilding a Holley carb. There is really no skill involved at all, very straightforward. I did one in a couple hours. I would sooner buy another used T5 that is known good than take it to a trans shop. You will end up with a huge bill, not worth it.
Old Sep 6, 2007 | 05:53 PM
Car: 1985 Camaro
Re: T-5 trouble
Where would i go to get the parts?
Old Sep 6, 2007 | 05:58 PM
Car: 2000 BMW M5
Re: T-5 trouble
Depends. You need to tear down to determine what broke. You may have a worn synchro slider/hub, such that the locking tangs just aren't grabbing anymore, or the springs in the hub may have fallen out (this happened to mine). Your gear is probably damaged from popping out, so you will most likely need a new gear. Any good trans parts warehouse will have new T5 gears and hard parts. I dealt with Spencer Hodes at Transmission Exchange Company (google it) a lot, but any real trans parts warehouse will have what you need. If you were local I could throw the trans together pretty quickly, especially now that I have a shop press in my garage. The T5 is lightweight and the parts are small and easy to deal with.
Old Sep 6, 2007 | 06:00 PM
Car: 1985 Camaro
Re: T-5 trouble
alright, thanks alot.
Old Sep 6, 2007 | 06:03 PM
Car: 2000 BMW M5
Re: T-5 trouble
What year is the trans? I need to know if it is world class or not. I have a parts manual and rebuild instructions I can send you. I also should have a full parts listing w/ #s so I can tell you what part #s you most likely need to buy, in addition to a master rebuild kit (synchros, bearings, seals. They are not at all expensive)
Old Sep 6, 2007 | 06:07 PM
86irocu's Avatar
Car: 1986 Iroc-Z
Re: T-5 trouble
you my first gear being bad have anything to do with the trans slipping? because i just replaced that clutch less than 1000 miles ago. i havent beaten on it and i broke it in corectly.
Old Sep 6, 2007 | 06:38 PM
Car: 2000 BMW M5
Re: T-5 trouble
A manaul transmission can't slip. Either the gears are meshed and the synchro is locked, or not. The bad 1st has nothing to do with your clutch slipping.
Old Sep 6, 2007 | 06:50 PM
86irocu's Avatar
Car: 1986 Iroc-Z
Re: T-5 trouble
its a brand new clutch... there shouldnt be anything wrong with it.
Old Sep 6, 2007 | 10:09 PM
Car: 1985 Camaro
Re: T-5 trouble
Its from a 85 Z28 305 carbed.
PurelyPMD
May 5, 2016 04:57 PM
mrbird
Oct 20, 2015 03:43 AM
luvofjah
Sep 26, 2015 08:28 PM
Lmancha96
Sep 25, 2015 08:11 PM
DARKmj16
Sep 9, 2015 04:07 PM
