THm 350 cable
Old Sep 8, 2007 | 11:36 AM
Freakazooid52's Avatar
Car: 1986 firebird
Transmission: THM350
THm 350 cable
Is the cable on a thm350 the same as a 700r4 were it being out of adjustment is a VERY bad thing?
Or am i thinking wrong here?(what does the cable do, and how can i set it up right)
Old Sep 8, 2007 | 04:15 PM
duckmanquacker's Avatar
Car: 84 Z28 / 88 Trans Am / 87 base
Engine: L69 H.O. / 468 BBC / 2.8 v6
Transmission: 89 700R4 / TH375B / 700R4
Axle/Gears: 3.73 open / 3.23 posi / 3.42 open
Re: THm 350 cable
the 350 cable is similar to the 700 but you cannot leave it unplugged on the 700, you can on a 350. with it disconnected on a 350 you have to manually downshift for passing gear.
Old Sep 8, 2007 | 04:21 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: THm 350 cable
The cable on a TH350 is only used for the kickdown, the adjustment of it is mostly a matter of individual preference.
Old Sep 8, 2007 | 04:26 PM
Re: THm 350 cable
thank you I was trying to simplify that.
Old Sep 8, 2007 | 08:36 PM
rjt76's Avatar
Car: 1986 iroc z
Engine: vortec 383
Transmission: th350
Axle/Gears: 3.73 moser 12 bolt true trac
Re: THm 350 cable
i spoke with transgo about this same issue a couple days ago. I was told cable needs to be hooked up to get the the "Detent" and governor tuning for full throttle will be effected otherwise.
leave it unhooked going with their full manual only kit only.
transmission in completely stock form i would not be able to say. as i did not ask that question.
Old Sep 8, 2007 | 08:46 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Re: THm 350 cable
Shifting will certainly be affected without the cable, but it's not a fatal thing like it would be with a 700R4.
IROCZDAVE (88-L98)
Nov 19, 2015 07:03 AM
TheTraut88
Sep 11, 2015 05:16 AM
angel2794
Sep 8, 2015 06:22 PM
TheTraut88
Sep 7, 2015 05:22 PM
Eric-86sc
Aug 24, 2015 09:01 PM
