Rear end swap
Old Sep 9, 2007 | 11:12 PM
afida15's Avatar
Rear end swap
i have a 89 IRoc z..is there any posi rear ends that will swap right onto my car with no fab work..or is there atleast the posi unit itsself like the gears and stuff that will work into my stock diff..i really want a posi rear end
Old Sep 9, 2007 | 11:31 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: Rear end swap
Do you have a 9 bolt or a 10 bolt diff?
Old Sep 9, 2007 | 11:52 PM
afida15's Avatar
Re: Rear end swap
its a 9 bolt rear end..
Old Sep 10, 2007 | 01:02 AM
AlkyIROC's Avatar
Car: 87 IROC L98
Re: Rear end swap
Yank it out and find a 10 bolt with a posi from a third or fourth gen. The 9 bolt is stronger but parts are non existent.
Old Sep 10, 2007 | 07:50 AM
IROCThe5.7L's Avatar
Car: 1988 IROC-Z
Engine: 427 SBC
Transmission: ProBuilt 700R4
Re: Rear end swap
This man speaks the truth.
Old Sep 10, 2007 | 12:55 PM
afida15's Avatar
Re: Rear end swap
alright il try..well if i find a 10 bolt will all my suspenison stuff work with it same like the 9 bolt..what i mean is will everything bolt right up. like springs and everything? it also has rear disk brakes so does a 10 bolt have disc?
Old Sep 10, 2007 | 06:49 PM
n8sz28's Avatar
Car: 85 camaro z28
Transmission: T56 6 speed
Axle/Gears: 3.27 borg warner 9 bolt
Re: Rear end swap
I BELieve that all parts from the 3rd gen rears and 4th gen rears should bolt right up the same as the 9 bolt. the only difference is most 4th gens have disk brakes so you would have to convert.not hard though its just a few brake lines. the 4th gens E- BRAKE are the only thing that doesn' fit perfectly but can be fabricated to work. also the 4th gens rears are about 3.5-3.8 inches wider than the 3rd gens so it looks like you have wider tires. do a search on this board you will find more info.
does anyone know what rear ends 4th gen wise come with posi. is it any v8 93-02 camaro or firebird or was it an option? let me know how to tell statistically because i'm looking into buying one and i want to make sure it has posi .
Old Sep 10, 2007 | 09:35 PM
afida15's Avatar
Re: Rear end swap
my car has Disc rear brakes now..but yea i really would like to have a basic swap and not alot of FAb work seeing that im only 17 but im in auto tech 3 so i could do the work there and have good knowledge on cars just not in that part
hectre13
Dec 11, 2023 08:14 AM
IroczFan
Oct 6, 2015 10:13 AM
hectre13
Aug 26, 2015 08:17 AM
mizz0313
Aug 12, 2015 06:45 AM
1992 Trans Am
Aug 8, 2015 08:16 PM
