flexplate question 700r4
Old Sep 13, 2007 | 10:27 PM
n8sz28's Avatar
Car: 85 camaro z28
Transmission: T56 6 speed
Axle/Gears: 3.27 borg warner 9 bolt
does a flexplate for a 700r4 interchange with other years of camaros 700r4. would a 85 700r4 flexplate hook right up to a 89 700r4 trans.
Old Sep 13, 2007 | 10:40 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: flexplate question 700r4
They'll interchange from 82-85, and from 86-92. It doesn't matter to the transmission, any torque converter will bolt to any flexplate, but the bolt pattern on the crank flange is different between the 1 piece and 2 piece RMS blocks.
Old Sep 13, 2007 | 10:51 PM
Mikz86TA's Avatar
Car: '86 Trans Am and '03 S-10
Engine: 355ci and 4.3l
Transmission: 700R4 and NV3500
Axle/Gears: 7.625/3.42 Auburn and 8.5/3.08 Gov-
X2
Old Sep 14, 2007 | 01:13 AM
n8sz28's Avatar
Car: 85 camaro z28
THANKS WHATS X2?
Old Sep 14, 2007 | 01:14 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
It means "the previous post, times 2"... or "I agree".
Old Sep 14, 2007 | 01:36 AM
n8sz28's Avatar
Car: 85 camaro z28
oh ok
so an 85 camaro with a stock 305 is a 2 piece RMS right? and will only work with the years listed 82-85 third gens
Old Sep 14, 2007 | 01:41 AM
strokermotor91's Avatar
Car: 91 Camaro RS
Engine: Small Block
Transmission: TH350 w/ 3000 stall convertor
Axle/Gears: 3.73 w/ powertrax locker
that is correct
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Apart from the crank hub, the block is absolutely identical externally to any other block that came in a thirdgen. You can put it in any year car, as long as you use the right flywheel or flexplate.
84z96L31vortec
Aug 20, 2017 12:16 AM
redmaroz
Aug 16, 2015 11:40 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
gwade12
Aug 8, 2015 08:17 AM
Leggman1
Aug 6, 2015 04:15 AM
