83 700r4...would it be bad if
Old Sep 17, 2007 | 01:15 AM
CrAlt's Avatar
Car: 83 TA
Engine: goodwrench 350
Would it be bad if nothing was plugged in to my 83 700r4? Would it just not lockup or would it burn its self out?
I know the TV has to be hooked up and its vital that it be set right. But does no lockup plug matter?
Im putting an aftermarket cam and intake/carb on. Removed all smog stuff and am putting a normal non CC dist in. The ECM is gona be all freaked out and im guessing its not going to know what to do about the lockup.
Old Sep 17, 2007 | 01:43 AM
darkride86T/A's Avatar
From: North Carolina(but you'll never take the DC out of me!!!)
Car: '91 Formula,'02 Silverado,'15 200s
Engine: L98, LQ4, and 3.6 Pentastar
Transmission: 4L60/4L80E/9HP48
Axle/Gears: 2.73posi/3.73posi/3.73
Re: 83 700r4...would it be bad if
From what Ive been told, 83' & 84' 700R4's will overheat if TCC isnt
hooked up.
Old Sep 17, 2007 | 10:14 AM
Mikz86TA's Avatar
Car: '86 Trans Am and '03 S-10
Engine: 355ci and 4.3l
Transmission: 700R4 and NV3500
Axle/Gears: 7.625/3.42 Auburn and 8.5/3.08 Gov-
X2
Old Sep 17, 2007 | 12:54 PM
duckmanquacker's Avatar
Car: 84 Z28 / 88 Trans Am / 87 base
Engine: L69 H.O. / 468 BBC / 2.8 v6
Transmission: 89 700R4 / TH375B / 700R4
Axle/Gears: 3.73 open / 3.23 posi / 3.42 open
X3, if you wish to remove the ECM then you must get one of the converter lockup boxes from B&M or other companies.
Old Sep 17, 2007 | 12:57 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
It will not lockup and burn itself out.
Old Sep 17, 2007 | 06:33 PM
CrAlt's Avatar
Car: 83 TA
And thats bad.
Thanks.
Old Sep 17, 2007 | 11:01 PM
1983 was the 1st year that GM put the 700r4 in the F-Body. If you can,this is
just a suggestion, try to find a late 87-up V-8 700 for your T/A. You should be able to pick one up(that actually works!!!!!) anywhere from $100-250.00 for a
stock one with converter. I just picked one up for my 86' T/A. I think I saw a
couple of threads for later model 700's( in CT!!!!!!!) for no more than $200.00.
I believe they were in the Engine & Drivetrain Parts for sale forum. Type in search for 700r4. If it's in your budget I'd go that route.
AmpleUnicorn88
Brakes
32
Nov 18, 2015 11:02 AM
3rdgenkindagal
Aftermarket Vendor Review
25
Oct 21, 2015 09:32 AM
L98GTA87
Oct 19, 2015 10:43 PM
dimented24x7
Sep 17, 2015 06:58 AM
gta892000
Sep 16, 2015 12:40 AM
