Driveline Vibration? Oh Noooo!
Car: 1991 Trans Am GTA
Engine: LSX (swapping)
Transmission: 4L60E (swapping)
Axle/Gears: 2.73 Posi 10 Bolt
Well, I have a problem, I get a surging vibration when I accelerate. It doesn't happen all the time, but occurs often enough. It feels like a grinding and it surges in and out. If I let off the gas and punch it down to drop a gear it smooths out and stops. It usually is at lower speeds and can be at say 2000 + rpm. It doesn't do anything while idling. Only when you are first accelerating, and again, it doesn't do it every time. The felling and noise almost made me think bottom end, but the fact that it doesn't always do it and that it doesn't do anything at idle threw me off. I checked the Universals which all seemed fine, but maybe they are seized, I never ripped em apart that far yet. Torque converter and flex plate bolts all seem fine and tight, this is really bothering me. Could it be in the tranny?
Car: 84 Z28 / 88 Trans Am / 87 base
Engine: L69 H.O. / 468 BBC / 2.8 v6
Transmission: 89 700R4 / TH375B / 700R4
Axle/Gears: 3.73 open / 3.23 posi / 3.42 open
Re: Driveline Vibration? Oh Noooo!
how is the color of the trans fluid?
Car: 1990 IROCZ Camaro
Engine: 350 4bbl, 200cc Heads, 270hr Cam
Transmission: 700R4 w/ Trans-Go shift kit.
Axle/Gears: GM 10 bolt Posi
Brown = bad
Red = good
Red = good
roysatikas
Sep 22, 2015 08:15 PM
