Noise in trans
Old Sep 23, 2007 | 04:01 PM
yino18's Avatar
Noise in trans
I floored the car today and it downshifted as normal and the tires did the usual slipping. Now I have a clicking/knocking that seems to be coming from the torque converter area. The clicking increases as speed increases. Car still shifting fine. This a 700R4, shift kit, light stall converter.
Would this be the flexplate, or any other ideas? Also, an estimate on repairs if you could. Thanks~
Old Sep 23, 2007 | 09:52 PM
one wheel peel's Avatar
Car: 84 camaro
Engine: 72 chevy 406 sbc
Axle/Gears: 3.42 eaton posi
Re: Noise in trans
LOL, READ DOWN A LITTLE I JUST HAD THIS PROB LAST WEEK,was bolts to crank were worn and wallowed out holes a little causing a knocking noise, my cost at a tranny shop here was 253.00 good luck, oh you can check by taking 3 bolts out of converter then slide it back away from flexplate then start car and see if noise is gone, worked for me.thanks to ideas i got from others here thanks
theshackle
Sep 17, 2020 08:26 AM
xxx3man`
Sep 23, 2015 10:37 PM
B_Dubya
Aug 26, 2015 05:09 PM
BlackBoulder
Aug 11, 2015 11:15 PM
hokis
Aug 9, 2015 03:57 PM
