Torque Arm
Old Oct 8, 2007 | 09:05 PM
572_Rat's Avatar
Car: 86 Camaro IROC-Z
Engine: 565ci 900 hp
Transmission: T56 Magnum by RPM Transmissions
Axle/Gears: Moser 9" w/4:56 Detroit Locker
Torque Arm
I have an 86 Iroc, I am putting in a Morrison 4 bar rear clip with a narrowed 9 inch, also using their weld in frame connectors. I am running a GM 572 crate motor with a procharger F2. With the full frame is it neccessary to still use the torque arm? and if so why
Thanks for the help
Old Oct 8, 2007 | 10:09 PM
RebornFromAshes's Avatar
Re: Torque Arm
I'll bite, but this is all a bit odd.
If you run a 4 bar or link suspension you can't use a torque arm.
Old Oct 9, 2007 | 02:22 PM
Shagwell's Avatar
Car: projects.......
Re: Torque Arm
if you're going to install a 4-link "back-half", then that's all you will be using. The subframe connectors would be a moot point, as you need to look into fabricating framerails, or having it done.
You're looking at tackling a MAJOR alteration with what would seem to be little knowledge of what you are doing. - Do a search under "back-half" and look at Stephen's car domain page. There will be A LOT of custom fabrication required for what you are talking about
also, this really should be under the suspension forum.
no green
Jan 9, 2016 09:22 PM
darwinprice
17
Oct 11, 2015 11:51 PM
loud91rs
Oct 5, 2015 10:05 PM
meeklay812
Oct 1, 2015 03:46 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
