Wheel Wobble?
Old Oct 8, 2007 | 10:37 PM
Orinackra's Avatar
Car: 06 SRM M6 GTO, 98 Grand Prix GTP
Wheel Wobble?
Hey guys, I cannot figure out what the heck is going on in my axle. Wheel wobbles a good inch on the rear driver side. I replaced the axle shaft, and swapped wheels, and it still does it. What kind of other things could make a wheel do that? Theres absolutely no play in the axle, like the shaft to the bearing clearance, we had the rear in the air, unmoving, so its not a control arm or anything like that. The only thing I can think of is that maybe both wheels I tried were bent (although it spins true on the front) or a bearing, or I dont know.
Old Oct 9, 2007 | 08:51 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: Wheel Wobble?
Best bet is to remove the wheel and drum (do NOT hit the brakes with the drum off!!) and see if the axle flange wobbles. Or maybe the housing, as it may be bent.
If this has a drum to disc conversion does the rotor sit square on the axle flange. Sometimes need to reduce the OD of the axle flange for the disc hat to seat on.
RBob.
obeymybird
Exterior Parts for Sale
Nov 3, 2015 08:10 AM
Saxondale
Sep 15, 2015 06:42 PM
punkmaster98
Sep 8, 2015 09:45 PM
turbobuick88
Wheels and Tires
Sep 8, 2015 08:27 PM
FormulasOnly
Sep 6, 2015 10:42 AM
