700r4 rating
Old Oct 11, 2007 | 11:21 PM
migman's Avatar
Car: 89 camaro
Engine: 383
Axle/Gears: 10 bolt posi
700r4 rating
does abyone know how much torque/horspower a 700r4 is rated at?
Old Oct 13, 2007 | 07:15 PM
Gramps's Avatar
Car: 87 Camaro IROC
Re: 700r4 rating
well although there is no number written down, the theory is 450-500hp. now with a stock trans and a suped up motor, your not gonna be happy with your ride anyways because you cant get your power to the wheels properly. if you upgraded your trans with a basic upgrade and shift kit, you'd easily get away with 500hp. i just had a trans built that should be able to handle my nitrious 650hp engine.
Old Oct 13, 2007 | 07:36 PM
Nasty-Z's Avatar
Car: 1980 Z-28 /1992 S-10
Engine: 496 /421 Stroker
Transmission: 700R4 / Tremec
Axle/Gears: 4.88 / 4.30
Re: 700r4 rating
I run a 700R4 behind the 496 in my 2nd gen '80 , all good parts in the build , and no problems so far . Cooling is key , it'll live behind good HP#'s with good build parts/maintence, mine has
Gotta love that 1st gear and the ability to carry 4.88's without having to stare at the tach needle in outer space on the highway.
HTH
TOM
Old Oct 13, 2007 | 10:43 PM
migman's Avatar
Car: 89 camaro
Engine: 383
Re: 700r4 rating
HTH
TOM
yeah, i have a th400 in my daily driver, it turns 3000 at 65, really costs at the pump.
i dont have nitrous, but 650hp is about what i have, what would i need to do to the trans to withstand the load?
Old Oct 14, 2007 | 12:08 AM
car_fixer's Avatar
Re: 700r4 rating
you can get built ones from several places for probably less than parts and labor to build it, unless you think you can tackle an auto trans rebuild and happen to have the needed tools and workspace. tci patc and several others sell them look into that most of them have hp ratings that they will garuntee their trans up to , but i have never had to go through warrenteeing one. ( i build my own)
Old Oct 14, 2007 | 12:14 AM
stevo the torpe's Avatar
Car: 91 maro
Axle/Gears: 373 locker
Re: 700r4 rating
i got mine built at a shop known all around in md billet servos kevlar bands shift kit free flow valves.2400 stall its ok but exspensive 700r4s are not performance oriented get a t 350 or 400 there better 700r would cost 2000 to hold 500 hp.i have blew 5 of them got this one built and still having probs
good cooling with b&mcooler and remote fan.overall 700r is a good every day trani
Old Oct 14, 2007 | 12:16 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Re: 700r4 rating
500 HP reliably, anything more and it will fail eventually.
http://www.pro-built.net/
http://www.bowtieoverdrives.com/
Old Oct 14, 2007 | 12:23 AM
Car: 91 maro
Re: 700r4 rating
yea but i aint putting 500 out
Old Oct 15, 2007 | 12:48 AM
migman's Avatar
Car: 89 camaro
Engine: 383
Re: 700r4 rating
oh, i was also wondering how much stonger a stock 4l80e is than a stock 700r4?
Old Oct 15, 2007 | 11:46 AM
Car: 91 maro
Re: 700r4 rating
idn about much stronger but is better for performance
Old Oct 15, 2007 | 10:07 PM
Nasty-Z's Avatar
Re: 700r4 rating
Lots stronger , but you give up the 3.06 1st gear in the 700R4 for the 2.48 that is in the 4L80E , also heavier and bulkier and uses more power .
A well built 700 will hold up just fine IMHO.
TOM
Old Oct 16, 2007 | 12:04 AM
car_fixer's Avatar
Re: 700r4 rating
I agree 4l80 is basically a 400 with overdrive. I also think a decent 700 would be better for you, keeping that 3.0 first gear is a plus and by the time you beefed up a 350 its not much more for the better gas milage of the 700 and with the price of gas rising like every day i would keep that in mind. I also wouldnt want to make that 4l80 fit in the tunnel thats kind of a bft.
Old Oct 16, 2007 | 06:45 AM
migman's Avatar
Car: 89 camaro
Engine: 383
Re: 700r4 rating
yeah, i defenetly dont want a 2.48 first gear.
Old Oct 16, 2007 | 06:51 AM
migman's Avatar
Car: 89 camaro
Engine: 383
Re: 700r4 rating
i have a chevy 3500 with a th400 and after i bought my camaro i thought about swapping out my th400 for a 700r4 its nice having overdrive, with the 400 i have to turn 3000 rpm to go 65. i would like to have a lower first than the 400 provides does anyone know of first in the 400. anyways i would like to swap, but ive heard that a 700 is not a good truck tranny, but some rv have them, thats a heck of a lot of weight.
Old Oct 17, 2007 | 08:25 PM
ditchbangr's Avatar
Car: One of 5
Engine: LB9
Re: 700r4 rating
The 700R4 was put in more trucks than anything else, that's why it has a 3.06 first gear.
LT1Formula
Oct 8, 2015 08:34 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
92projectcamaro
Sep 29, 2015 07:07 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
6998poncho
Sep 25, 2015 02:56 PM
