4.10 or 3.73?
4.10 or 3.73?
i have a 88 iroc camaro 305 tpi 5 speed which currently has 3.08 rear gears im looking for a small improvement in my 1/8th mile time im running a 9.32 right now and i want to get into the 8's this car is getting around 26mpg on the highway and i was also curious how the sawp would effect economy and information woudl be appreciated.
Car: 1988 Camaro
Engine: 383 Stroker
Transmission: Probuilt 700 R4
Re: 4.10 or 3.73?
The 3.73 would give you better economy, but for the most part I would go with the 3.73
Car: 1988 Camaro
Engine: 383 Stroker
Re: 4.10 or 3.73?
There is not much difference between both. But if this is also for the streets, the 3.73 would be much better. Definitely go for the 3.7's
Car: 1988 camaro sport
Engine: 355
Transmission: 5 speed
Axle/Gears: Ford 9 inch - 4.11 gears
Re: 4.10 or 3.73?
I picked up 2 tenths in the quarter by going from a 3.73 to a 4.11. Dont know about mileage, its a drag car.
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Re: 4.10 or 3.73?
4.10 gears are too much for a stock TPI. Stick with 3.73's. Remember to change your speedo gears in the tranny. You need a 7 tooth drive and 21 tooth driven.
[ON] 9 Bolt Axles Partout
6speedIROC
16
Mar 15, 2023 08:33 PM
