v8 T5 behind V6
Old Oct 25, 2007 | 08:13 PM
tmkhum's Avatar
v8 T5 behind V6
I wonder if y'all can help a project I'm working on. I've got a HT 3.4 V6 crate motor and I want to use a WC V8 T5 transmission. I need to use a S-10 V6 housing to get the shifter orientation correct. So I'd have a 3.4 V6 with V6 bellhousing and V8 T5. What flywheel/clutch setup could work for this application? The V6 clutch won't work because of the spline count.
1973 MGB --->camaro powetrain
Thanks,
Tom
Old Oct 25, 2007 | 08:16 PM
Re: v8 T5 behind V6
Use a V8 clutch disc.
Old Oct 25, 2007 | 08:43 PM
tmkhum's Avatar
Re: v8 T5 behind V6
I thought the V6 clutch disc was 9 1/8" and 14 spline and the V8 clutch disc was 10 3/8 and 26 spline. So with a V8 clutch wouldn't you also need the V8 flywheel? I did not think a V8 flywheel would fit inside V6 bellhousing.
Thanks,
Tom
Old Oct 25, 2007 | 08:47 PM
KrisW's Avatar
Car: 88 V6 'bird/89TBI bird/85 T/A
Engine: 2.8/TBI/TPI
Transmission: V8 T-5/700R4 x2
Axle/Gears: 3.42 open/2.73 open/ 3.27 9 bolt
Re: v8 T5 behind V6
I used a 95 S10 2.2 liter 4 cylinder clutch disc. It is 9 1/8" diameter and 1 1/8" 26 spline input shaft - just like your V8 transmission!
I used my factory pressure plate.
