drum to disk rear end, shift kit questions
i have an 86 sport coupe 305, with an open diff drum 2:73 rear end. i have the opportunity to get a 3:73 posi disk rear end. is it a direct swap? what will i need to get the job done?
also, i was thinking of adding a b&m shift kit to my 700r4. can i install a shift kit with the tranny still in the car?
thanks
thanks
Axle/Gears: '01 3.42 10 bolt
Re: drum to disk rear end, shift kit questions
the rear should be a direct swap. some say to change your proportioning valve to a 4 disc one but i have a drum rear proportioning valve on my car right now with no issues.
stay away from the B&M shift kit. most on this board will tell you the same thing. go with transgo if you want a good shift kit.
Car: 91 RS Camaro, 75 L82 Corvette
Engine: LO3, 383 Stroker
Transmission: 700R4, TH400
Axle/Gears: 4th gen 3.23 posi/LS1 discs, stock
You'll have to change the drive and driven gears on the tail shaft of the transmission if you want the odometer and speedometer to read correctly.
how to change the speedo gears
hectre13
Dec 11, 2023 08:14 AM
hectre13
Aug 26, 2015 08:17 AM
dhonda200
Aug 11, 2015 11:50 PM
