Help! Turbo 350 Leftover Part...
Old Oct 26, 2007 | 09:28 PM
jimchristiansen's Avatar
Car: Jeeps
Engine: 1970 4 bolt 350, 19000 miles & TPI
Transmission: Tubo 350
Axle/Gears: 4:11
I have a part that I don't know what to do with... Maybe an X-Mas decoration hanger!! My buddy took the tranny apart and said "Don't worry, I'll be back to show you how to put it together..." He is gone now...
I've got a great rebuilding page off of internet but it doesn't show where to use this left over clip.
Here is a pic of it at www.christiansens.ca/clip.jpg
or
Please- any ideas welcome!
Jim
Car: Jeeps
Axle/Gears: 4:11
Re: Help! Turbo 350 Leftover Part...
I should have said that the screw driver is pointing at it.
Thanks again, Jim
Old Oct 26, 2007 | 09:52 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Bah ha ha ha! You should really invest in a rebuild book if you want to rebuild a transmission.
That's called an anti-clunk spring. It goes in open end out beside the low/reverse drum. Without it the low/reverse support will fret or beat out the case eventually destroying the case.
Strip it down again. The low/reverse is at the back of the tranny.
Old Oct 26, 2007 | 09:57 PM
JAYDUBB's Avatar
Car: 1991 Camaro RS
Engine: L03 305 V-8 (for now ;) )
Transmission: T-5 5 speed
Axle/Gears: stock... whatever that means :)
I knew he was referring to that clip before I even opened this thread. I made the same mistake when I rebuilt my first Turbo 350...
Old Oct 29, 2007 | 03:18 PM
Car: Jeeps
Axle/Gears: 4:11
Thanks for the help!
Jim
Old Oct 29, 2007 | 06:35 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Is it fixed?
Old Oct 30, 2007 | 12:05 PM
Car: Jeeps
Axle/Gears: 4:11
Yes, thanks.
I found everything that I needed at google.com/books. It is together with the new output shaft and t-case adapter in place and should be going into the little Jeep this weekend.
Jim
dcd2236
Exterior Parts for Sale
Aug 19, 2018 02:27 PM
transamgta87
Sep 1, 2015 07:07 PM
camaro71633
Sep 1, 2015 10:24 AM
Eric-86sc
Aug 24, 2015 09:01 PM
crazynights
Aug 21, 2015 06:53 AM
