1994 4l60e slow going into drive
Car: 92 T/A VERT
Engine: LB9
Transmission: AUTO
Axle/Gears: 7.5 / 3.42's
Operates normally under all other conditions. This is in a 94 formula that has had the engine replaced. Is it possible that the front pump or seal may have gotten messed up during the install? It takes about 2-3 seconds to go into gear after you shift into drive.
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Re: 1994 4l60e slow going into drive
I'm sorry but we have to limit topics to thirdgen cars and parts only. Try over at http://www.camaroz28.com/
Have you checked the tranny fliud to make sure its full?
smokingss
LSX and LTX Parts
Mar 3, 2016 07:40 PM
