Disconnect TV cable for dyno runs?
Old Oct 29, 2007 | 09:53 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
I have heard of ppl disconnecting the TV cable and pulling it out half way to keep pressure up for dyno runs to keep the trans from downshiftin in third gear
I want to re-dyno my car this weekend and being a 700r4, i cant keep it from downshifting below 3800 rpms and i never get to see my TRUE power curve and torque
Is this safe on the trans? will half pressure be enough for WOT for 3 runs?
I wil also be locking my converter up at a low mph in third so i can see more power to the ground. Will this effect anythign on the trans, like burning up clutches?
Old Oct 29, 2007 | 10:04 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
Re: Disconnect TV cable for dyno runs?
Go to the wrecking yard, find an old 80s chevy/gmc truck, van, suburban, blazer/jimmy with the 6.2 diesel. Take the governor. Swap the governor into your TPI car. It will keep the engine from downshifting above about 2,500-3,000 rpm. I put one in my 700r4 in my Van when I went to dyno. Made a 3rd gear pull from 1,800-6,500 rpm with my old 305.
Old Oct 29, 2007 | 10:05 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
man i dont think i can find one in time or want to go thru that effort just for a dyno run LOL
Old Oct 30, 2007 | 12:06 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
No I wouldnt trust that method to be safe on the trans.
The computer is already set up to lock the converter above 70 MPH, which at 3500 RPMs you're faster than that. I dont see how manually locking it will help.
Old Oct 30, 2007 | 02:22 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
my converter is set to lock up at 118mph now but it used to be 88mph stock. for the dyno run i wanted to lock it up at 40mph in third and do the pull from whatever rpm that was with the TV disconnected. Before when i dyno'd it, each time the converter locked up it showed 10-15whp and wtq more.
but now i guess i'll set it to lock at 63mph which is just over 3700ish rpms from what it looks like on my tach and just do my pulls from 3700-5500rpms again...kinda dissappointing. but thats where the power is so why look elsewhere?
Old Oct 30, 2007 | 02:27 PM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
That would lower the line pressure and cause the trans to slip and burn up.
There is no easy solution for that problem.
Old Oct 30, 2007 | 02:30 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
oh well thanks for your input..i'll just dyno it like i have before then. hope to see 260's whp
Frozer!!!
Jan 19, 2024 04:55 PM
Caspar
Jun 19, 2016 11:19 PM
Spd-Kilz
Interior Parts Wanted
Aug 15, 2015 12:12 PM
ZZ42Fast
Aug 10, 2015 08:20 PM
