Borg Warner T-56 with Mechanical Speedo?
Old Nov 5, 2007 | 04:04 PM
CanadianRoots's Avatar
Car: 91 Camaro RS
Engine: 305 TBI *355 Coming Soon*
Transmission: 700R4 *T56 Coming Soon*
Axle/Gears: 323
OK so I'm looking for some help from you guys here with this one.
I just got finished pulling apart my parts car which had a Borg Warner T-56. The thing that has me kinda puzzled is that it was a Mechanical Speedo setup which I have never seen before.
My car which is a 91 RS currently has an electrical speedo...
Is there a way to make this work short of replacing my gauge cluster with a custome one??
Also correct me if I'm wrong but the plug shown in the first picture is the Reverse Lockout Solenoid correct?
The second picture is a picture of the opposite side of the trans and that is the electrical connection for the reverse lights??
Any help will be greatly appreciated...
Attached Thumbnails Borg Warner T-56 with Mechanical Speedo?-parts-001.jpg   Borg Warner T-56 with Mechanical Speedo?-parts-002.jpg
Old Nov 5, 2007 | 04:53 PM
Re: Borg Warner T-56 with Mechanical Speedo?
I've never seen one like that either. What is this parts car?
There are several things you can do.
Looks like it uses the T-5 style cable housing; so you can just get the corresponding VSS and the correct gear to match your rear end.
http://www.transmissioncenter.net/sp...____va.htm#350
That tail housing is worth at least $300 PLUS a normal one in exchange, on the open market. That's enough to trade it out for the usual kind, buy the Dakota Digital pulse divider, and make a profit.
So there's a couple of options for you.
Old Nov 5, 2007 | 10:18 PM
Car: 91 Camaro RS
Axle/Gears: 323
Well I'm gonna go out on a limb and say that it should have close to the correct gear in it due to the fact that the car that I pulled it out of had a newer rear end with 373 gears in it. Now my car has 343 but I am probably going to be upgrading to 373 gears at some point.
OK so I'm going to show my lack of knowledge with this one... What do you mean by VSS??
Thanks again for the help!!
Old Nov 6, 2007 | 05:17 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Vehicle Speed Sensor.
JamesC
Old Nov 6, 2007 | 07:03 AM
6speedIROC's Avatar
Car: 86 IROC
Engine: LQ4 6.0L
Axle/Gears: 3.55 8.8
Do a search for "Jags That Run" and start reading.
http://www.jagsthatrun.com/V8-chapte...ed-Sensors.pdf
http://www.jagsthatrun.com/Pages/Par...ilHousing.html
I'd sell the modified tailshaft housing, or swap it for a stock one and get the pulse divider as well.
Old Nov 6, 2007 | 07:46 AM
It's not modified.
I have one of the JTR ones in my car. I know.
This one is actually cast differently.
Old Nov 6, 2007 | 11:18 AM
vbMike's Avatar
Car: 1987 Camaro IROC-Z28
Engine: TPI 350ci L98
Transmission: T56 - Hurst Shifter
Axle/Gears: BW - 3.70
Yea I think it might be the aftermarket version of the T56. It can be gotten with either a cable or electronic style speedometer.
Maybe it's just the pictures but the tail housing looks shorter than a factory T56 and the shifter mounting plate looks shorter as well which leads me to believe it's the aftermarket version.
You may be able to swap the speed senor as someone else suggested but it's hard to say if it will work. You may have to pull the tail housing off and change the speedometer drive gear. Better to do it now than after it's in the car.
Yes, the picture with the wires comming out is the reverse lockout and the plug on the other side is the reverse light switch.
It doesn't show in the picture but see if there is another switch in from of the reverse lockout. That would be the CAGS switch, all the factory camaro/firebird t56 had them. If it doesn't it's probably the aftermarket version.
Old Nov 6, 2007 | 11:55 AM
Here's a nice crappy pic of a stock Camaro/Firebird one that I ganked off of an eBay listing.
The length looks about the same to me.
But you can CLEARLY see the casting differences.
Oh... and note how the shifter is different.
Attached Thumbnails Borg Warner T-56 with Mechanical Speedo?-t-56-drivers-side
Old Nov 6, 2007 | 12:05 PM
Car: 91 Camaro RS
Axle/Gears: 323
Yeah there are no other plugs.
From what it sounds like it might just be easier for me to do what I was actually planning on doing eventually anyway, which is swapping out my cluster for a custom built one and just get a cable driven speedo.
I'm pretty sure the T-56 already has drive/driven gears in it that are close to correct since the car this came out of had 373's in it. I have 343's and the only thing that might screw things up is the diameter of the wheels since he had 15" inch wheels and I have 18" inch wheels.
Old Nov 6, 2007 | 12:50 PM
6speedIROC's Avatar
Car: 86 IROC
Engine: LQ4 6.0L
You're right, didn't notice that it was cast like that. Shifter is further forward as well.
I modded mine to have both mechanical and the original VSS for my LT1 PCM...
Old Nov 6, 2007 | 06:25 PM
Car: 91 Camaro RS
Axle/Gears: 323
If I get a VSS will that allow my electrical gauges to work with this T-56? If so, where can I get one and what exactly is involved with installing it?
Thanks Again Guys!
-Chris
Old Nov 6, 2007 | 07:20 PM
See the link I posted above. Give them a call.
Old Nov 6, 2007 | 07:26 PM
vbMike's Avatar
You could proabably swap in a gauge cluster from an 85 - 89 Camaro since that uses a cable speedometer. I would think that would be an easy swap.
Lbibb
May 5, 2016 12:00 AM
sjorgens
Oct 1, 2015 07:54 PM
rs_z28_vert
Sep 30, 2015 09:47 PM
dbrochard
Interior Parts Wanted
Sep 28, 2015 07:40 PM
mfp189
Sep 27, 2015 09:25 AM
