Pilot bearing options for TKOs?
Old Nov 5, 2007 | 04:10 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Ok... So I found out that the Lakewood conversion pilot bearing, which is basically a bearing used for lawnmower decks and stuff with a knurled sleeve around it, doesn't clear the hub of the clutch. As the clutch disc wore, the hub was forced into bearing cover and caused the bearing to spin in the crank, doing even MORE damage to my motor. That, and it looks like it also caused the clutch disc to crack.
Are there any other options out there for the pilot bearings for TKO's?
Old Nov 5, 2007 | 06:09 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Pilot bearing options for TKOs?
forte's parts connection makes one, have you tried that one yet?
Old Nov 5, 2007 | 08:06 PM
Car: 88 Camaro SC
Engine: SFI'd 350
I tried that one early on with terrible results. There is a stepped area in the crank to retain the stock pilot bushings. The TKO bushing rides up onto this area causing it to pinch down on the input shaft, seizing it in place. I may still try another out of desperation, though, and this time have part of the bushing cut down so it clears the step in the crank.
Old Nov 5, 2007 | 08:21 PM
toms84ss's Avatar
I used a stock Chevy bronze bushing. No problems so far.
Old Nov 6, 2007 | 07:28 AM
Car: 88 Camaro SC
Engine: SFI'd 350
I have one thats actually a mustang transmission, so the ID of the chevy bushing is too small.
Old Nov 6, 2007 | 08:00 AM
toms84ss's Avatar
Stock Chevy honed to fit what ever ID you need?
Old Nov 6, 2007 | 05:53 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
ohh dont tell me that!
was is the old broze style one he had or the roller type?
84LsxZ28
May 17, 2020 02:21 PM
customblackbird
Oct 1, 2015 04:30 PM
david068513
Sep 18, 2015 10:36 AM
IROCZDAVE (88-L98)
Sep 17, 2015 07:43 AM
64Chief
Sep 12, 2015 08:05 AM
