speedo acting up on T5
Old Nov 6, 2007 | 10:55 AM
Saculia's Avatar
Car: currently a 91 G92.
Engine: 305TPI
Transmission: Borg Warner WC 5 speed
Hi guys,
I have a 91 formula WS6 T5 with a 305 TPI. My speedometer has been acting up a bit. It happens under load in 5th gear only. It is fine in the rest of the gears. When I step on the gas, the needle will drop to 0 mph. When I let my foot off, it goes back up to the correct speed. It is worse when it is cold, and the problem disappears when it is warm.
What do you think is causing my problem? Bad speed sensor? How do you diagnose the cause?
Thanks in advance for your help.
Old Nov 6, 2007 | 11:49 AM
Re: speedo acting up on T5
Mine used to do that too.
It needs the "sleeve" that the gear is in. You probably still have the crappy chinesium one that came in the car. It's so totally weenie, it lets the gears move to the side and mis-align enough to no longer spin the cable. A replacement one is steel. Unbelievably better. It's about like comparing a kid's toy plastic screwdriver to a Snap-On screwdriver, except even more like that.
http://www.transmissioncenter.net/sp...____va.htm#350
If you're lucky, it hasn't torn up the gears; but it probably has. I'd strongly recommend having AT LEAST the driven gear on hand for when you change it out.
Old Nov 6, 2007 | 11:54 AM
Saculia's Avatar
Engine: 305TPI
Does the transmission need to come out in order to replace these gears?
Old Nov 6, 2007 | 11:57 AM
The drive gear, yes; but not the driven one. It comes out with the sleeve.
Old Nov 6, 2007 | 01:40 PM
Saculia's Avatar
Engine: 305TPI
How accessible are the sleeve and driven gear? Is it complicated to change them? Is the driven gear also made up of plastic?
thanks
Fanatic1074
Oct 3, 2022 05:57 AM
RedLeader289
May 28, 2019 01:47 PM
Luigytico09
Oct 1, 2015 08:46 AM
rs_z28_vert
Sep 30, 2015 09:47 PM
ironbmt
Sep 27, 2015 06:00 AM
