Will it fit?
Old Nov 10, 2007 | 09:01 PM
Romilin's Avatar
Will it fit?
Will a t5 from an 87 v8 transam bolt right up to my 92 camaro? And what all is involved in changing the speedo to a manual speedo(Camaro) vs the electronic(trans Am)?
Alos is there any good source for parts for the t5? Any help would be greatly appreciated!
Old Nov 10, 2007 | 10:57 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Re: Will it fit?
Yes it will, but the 87 is the first design T5. The 88-92 2nd design is slightly better.
The electronic speedo and cable speedo on a T5 are interchangeable. Remove one, replace with the other.
Old Nov 11, 2007 | 01:58 PM
Romilin's Avatar
Re: Will it fit?
The gear on the shaft doesnt need to be changed? I am getting the tranny without the cable, and will be using the stock manual cable....
Old Nov 11, 2007 | 02:21 PM
Re: Will it fit?
Maybe, maybe not. It depends. Has nothing to do with electronic vs cable, has more to do with the number of teeth it has.
Fronzizzle
Feb 9, 2017 09:31 AM
New2Chevy
Sep 28, 2015 12:35 AM
armybyrd
Carburetors
25
Sep 13, 2015 01:49 PM
BOOT77
Sep 5, 2015 03:55 PM
Formula_88AE
Sep 3, 2015 01:47 PM
