trans problems
Old Nov 11, 2007 | 09:55 PM
70gmc's Avatar
Car: 1970 GMC LWB Street strip
Engine: 383 stroker
Transmission: 350TH
Axle/Gears: 12 Bolt 4:11
trans problems
700R4 in a 92 rs with a 305. I was just driving it one day when it started mess up. I have park nuetral reverse, but only 1st gear, it wont shift out of first, even when tryin to shift it manually.
Im wondering if the detent cable didnt come loose down in the trans. up on the tbi i can pull the dentent cable out towards the front of the car about 1 1/2 - 2 inchs. Isnt it suppose to be alot tighter?
I would appreciate any and all help.
Old Nov 11, 2007 | 10:07 PM
87zjeff's Avatar
Axle/Gears: '01 3.42 10 bolt
Re: trans problems
is there any tension at all on the tv cable? if not then that could be the problem.
Old Nov 11, 2007 | 10:11 PM
70gmc's Avatar
Engine: 383 stroker
Transmission: 350TH
Re: trans problems
no, with the throttle in the idle position i can pull up (towards the hood) about a inch, and the push the cable down towards the intake a inch also.
I just know the tv cable tells the trans when to shift, and i figured if it came loose or frayed in the pan then it wouldnt be able to read the throttle postion to tell it when to shift.... sound like the problem???
Old Nov 11, 2007 | 10:22 PM
87zjeff's Avatar
Re: trans problems
just sounds like it is loose/ mis-adjusted. if that is the case, it prolly burnt the 2/4 band and that is why you can't upshift out of first. the 700r4 is real sensitive to that cable.
Old Nov 11, 2007 | 11:52 PM
klause83z28's Avatar
Car: 83 z28
Engine: boat anchor 305 (ex CFI)
Axle/Gears: 3.23 10 bolt
Re: trans problems
Yep, sounds like you fried the intermediate band. did the symptoms happen all of the sudden, or did the symptoms become more prominant over time? If you want I can stop on over some time at look at for you.
Cheers!!!
Old Nov 12, 2007 | 09:30 AM
antoine's Avatar
Car: 1988 camaro z28,1997 camaro lt1
Engine: 355 afr 195 heads,tpis big mouth
Transmission: 700r-4 built by me 3-4 z pack
Re: trans problems
pop the govenor cover off and check the teeth on the govenor shaft.
Old Nov 12, 2007 | 11:09 AM
ParkerTPIz's Avatar
Re: trans problems
how many miles are on it.....it could simply be that u just need to service and flush your tranny ( filter, fluid, gasket)......
ive had it happen; start off small.....check all the little things first...
good luck man
84z96L31vortec
Aug 20, 2017 12:16 AM
TheJoeY88
Dec 31, 2016 07:30 PM
gta power
Aug 13, 2015 06:15 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
