Clutch Pedal Will Not Depress Fully
Old Nov 12, 2007 | 11:24 AM
JesasaurusRex's Avatar
So just playing around in the car and push the clutch pedal down like I do once n a while playing race car driver and the pedal doesn't go down fully. It seems to stop right before it touches the neutral safety switch. I haven't slide under the car yet and probably won't today, but i did open the fluid reservoir and see that it was almost completely empty. So my question is, will air in the line cause my clutch pedal to not depress fully?
-Rex
Old Nov 14, 2007 | 01:25 PM
vbMike's Avatar
Car: 1987 Camaro IROC-Z28
Engine: TPI 350ci L98
Transmission: T56 - Hurst Shifter
Axle/Gears: BW - 3.70
Re: Clutch Pedal Will Not Depress Fully
No. Air in the line shouldn't prevent you from fully depressing the pedal.
Old Nov 14, 2007 | 02:47 PM
well i tried to bleed the system and a couple pumps into it the slave cylinder exploded...was kinda cool, anyhoo bought another one blah blah blah let yall know how it turns out
Old Nov 14, 2007 | 07:34 PM
vbMike's Avatar
Yes you definatly don't want to force them. I almost blew mine up when I first installed it. Pedal wouldn't move, I found out I had installed the clutch fork wrong.
Old Nov 15, 2007 | 01:09 AM
I didn't just install it, this was the same one that was working perfectly fine for years and years. I disconnected it from the bellhousing and opened the bleeder valve and voila, the clutch went to the floor. So i decided to re bleed it and then a few pumps into it it just shot all the parts out. So now I have a new one insatlled but I have yet to bleed it. Doesn't matter if I bleed it with the pushrod on the clutch fork or just hanging freely does it? Reason I ask is because when I bled the original one it wasn't against the clutch fork and blew all the pieces out. I doubt thats the problem and it probably doesn't make a difference since I can clearly remmeber having it disconnected before and pressing the clutch in and out with no problems...but ya never know so that's why i'm askin.
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
meeklay812
Oct 1, 2015 03:46 PM
mfp189
Sep 27, 2015 09:25 AM
ironbmt
Sep 27, 2015 06:00 AM
