HELP WITH POSI
Old Nov 16, 2007 | 02:41 PM
85camarojunkie's Avatar
Car: Camaro coupe
HELP WITH POSI
I got a rear end i cut out of my 350 formula. want to put it in the camaro mine is a 10 bolt and the bird rear end is the 9 bolt. the tag says its a 3.27 and i kow it is i counted them. but i only want to put it in cause well posi and disc brakes. besides the contol arms. what do i need for the brakes. i know the disc needs 2lbs to run but factory drums have 10lbs. besides the lines what you think.
Or if somone wants to buy it $250 OBO
Old Nov 16, 2007 | 10:32 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Re: HELP WITH POSI
I think you just buy the wilwood adjustable proportioning valve and put it underhood. Done deal.
Old Nov 20, 2007 | 01:00 PM
Car: Camaro coupe
Re: HELP WITH POSI
i never even looked. i just thought about ripping one off of a disc car. that helps thanks
KO1
16
Oct 15, 2015 05:00 PM
92projectcamaro
Sep 29, 2015 07:07 PM
