TKO 600 driveshaft
Old Nov 19, 2007 | 09:24 PM
noroxus's Avatar
Car: 1984 Z28
Engine: 360ci SBC
Transmission: WC T5
Axle/Gears: 9 bolt 3.27 Posi
TKO 600 driveshaft
does anyone sell a driveshaft compatible with the TKO 600 yet?
does the TKO 600 share a driveshaft with any of the sizes listed on the spohn site?
and lastly, does anyone know the exact size of the driveshaft id need?
Old Nov 20, 2007 | 04:07 AM
Pat Hall's Avatar
Re: TKO 600 driveshaft
Your stock length driveshaft works just fine with the TKO. The only thing you need is the proper slip yoke to go in the back of the trans (Ford C6 style-31 spline), and a conversion u-joint that has 1310 (stock thirdgen) spacing on one cross of it, and 1330 (Ford C6) spacing on the other cross. If you bought the TKO new, it should've come with the slip yoke. If you wanted to spend the money for a Spohn driveshaft, you could have them fab one up for you that's stock thirdgen length with 1330 ears on the trans end, and regular 1310 on the end that attaches to the pinion yoke. That would be the more expensive way, but you'd have a heavy duty driveshaft and be able to use a standard 1330 u-joint. If you're on a budget, just get the C6 slip yoke, if you don't have it already, and buy a 1310/1330 conversion u-joint.
Old Nov 20, 2007 | 02:57 PM
noroxus's Avatar
Car: 1984 Z28
Engine: 360ci SBC
Transmission: WC T5
thank you very much.
Old Nov 24, 2007 | 06:45 PM
Black Betty's Avatar
Car: '86z28 blacked out/'87 iroc yellow
Engine: '86-305 4bbl, '87-305 tpi
Transmission: '86-tremec tko600, '87-700r
Axle/Gears: '86-3.23, 87-? stock gear
My tko came with an adapter plate that goes on the bell houseing and turns the trans strait instead of it sitting at an angle(like your stock t-5) That adapter added 1 inch to my overall length. When i had the ford slip yoke installed (which came with my tko) on the stock driveshaft they also cut it down 1 inch and rebalanced. My total bill was $130
Old Nov 24, 2007 | 06:53 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
ive got that adapter and i did not need to shorten anything
Old Nov 24, 2007 | 07:52 PM
Hmmm...I went from a stock t-5 to a tko and my driveshaft would not go in. I was so embarrased when i went back to the hydralics shop to have it shortened that i didn't measure the first time. But i took an inch off and it fits perfectly. I don't know where the difference is. Noroxus, maybe you should leave this detail for last and measure for yourself once the set up is installed.
Old Nov 26, 2007 | 03:08 AM
Pat Hall's Avatar
You can generally slip it right in place because the stock slip yoke usually doesn't go all the way in to the back of the trans. My stock yoke has almost 2 inches of slack left in it before it's flush with the rear of the trans, so most times an extra inch in length doesn't matter. This tolerance differs between cars, so there is the rare ones that'll need to be shortened up a bit.
IROCZDAVE (88-L98)
Nov 19, 2015 07:03 AM
topteam54
Oct 6, 2015 12:21 AM
loud91rs
Oct 5, 2015 10:05 PM
apie2546
Sep 20, 2015 01:03 PM
89newfun
Sep 16, 2015 09:28 AM
