noise in rear at 3to 5 mph forward or reverse
Old Nov 20, 2007 | 06:57 PM
frirebird952's Avatar
Car: 86 ta ws6 silver and gun metal
Engine: 305 fi lb9 eng code f
Transmission: 700 r4 with shift kit
Axle/Gears: lim slip not sure gears
i have a 86 transam 305 lb9 tpi it has the ws6 package 4 wheel disc brakes a ttabout 2 or 3 miles per hour it makes a scraping noise in the rear end you can feel it i have looked at the brakes there no fluid leaking from the axel and the rear end is full am taking it to a shop and going to put it on a lift to see it better anybody have this prob before at high speed it not make any vibe or noise
Old Nov 20, 2007 | 07:31 PM
KrisW's Avatar
Car: 88 V6 'bird/89TBI bird/85 T/A
Engine: 2.8/TBI/TPI
Transmission: V8 T-5/700R4 x2
Axle/Gears: 3.42 open/2.73 open/ 3.27 9 bolt
Re: noise in rear at 3to 5 mph forward or reverse
Is your car a 5 speed? I've had the front pinion actually loosen up and grind while moving around a couple of times. Is your rear end leaking at the front seal?
Old Nov 21, 2007 | 04:31 PM
it is a 700r4 trans,its not leaking any were that i can see like i said im taking it to the shop ,to see it better the sound is like the wheel is rubbing metal ,i checked that ,even changed the wheels still same sound i looked at the brakes nothing i can see i hope i get it to do it with it on the lft theni , can see it hopefully ,might be the brakes but not know yet any other sugestions will be apree has anybody else have trouble with the lmtd slip rear ends ??its 4 wheel disk ws6 package .
Vintageracer
Jan 10, 2020 05:33 PM
B_Dubya
Aug 26, 2015 05:09 PM
mizz0313
Aug 12, 2015 06:45 AM
BlackBoulder
Aug 11, 2015 11:15 PM
hokis
Aug 9, 2015 03:57 PM
