a feq quick driveshaft loop questions
Old Nov 30, 2007 | 08:02 PM
IROCZman15's Avatar
Car: 1987 IROC-Z
Engine: 406 on N20 w/ EFI
Transmission: P.B. 700R4
Axle/Gears: 12 bolt w/ 3.91
did a search; didnt find exactly waht i was looking for tho:
im looking for a BOLT IN driveshaft safety loop.. i know lakewood makes one.. but is it really bolt in? bending required?
do you have to remove the driveshaft to install this? or can the driveshaft stay in place?
where do the bolts go thru the floor into? under the seats? center console?
i want it to be safe and preventative and will be installing it myself. i jsut want to mostly know if i gotta pul the driveshaft out. and how it actually mounts and wahts involved
any and all advice is appreciated
thank u
oh; and im running a hooker 3" cat back. with Alston subframe connectors (that go near the driveshaft) and a stock driveshaft and stock t.q. arm
Last edited by IROCZman15; Nov 30, 2007 at 08:04 PM. Reason: Automerged Doublepost
Old Dec 1, 2007 | 01:19 PM
BOTTLEDZ28's Avatar
Transmission: A4
Re: a feq quick driveshaft loop questions
different comapanies make different designs and so me allow the shaft to stay in place during installation. Your best bet to to talk to guys thathave them and see how they installed them. Some require the removal of the interior to drill holes through the floor, ya really sucky if you ask me. Shop around and look for one that uses existing holes under the car.
if you end u having to remove the DS to install it then dont worry, its nothing hard at all. it like removing a wheel. There is 4 bolts holding it to the yoke on the rearend. Just remove them and tap the DS lightly with a rubber mallet and it will break free and come out
Old Dec 1, 2007 | 01:31 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
If you buy a third gen specific driveshaft loop, it will be a basic bolt in with little to no modifications required. They bolt through the floor under the seats. They are always a multi piece item that doesn't require removing the driveshaft.
The third gen specific loop has the proper bends for the contour of the floor and to clear the torque arm. Generic loops need some fabrication work to get them to fit.
A better system is to buy an aftermarket torque arm that has the loop incorporated into the torque arm or tranny crossmember.
Old Dec 4, 2007 | 07:03 PM
IROCZman15's Avatar
Car: 1987 IROC-Z
yea, ive seeen the spohn one, it looks like it hangs way low; that might be a problem for me
im prob guna go with the lakewood one
thanks for the help and insight guys
CORV3TT3
Aug 23, 2015 11:26 AM
redmaroz
Aug 16, 2015 11:40 PM
happyhapka
Aug 15, 2015 04:42 PM
