will it fit
Old Dec 17, 2007 | 09:40 PM
dealerkiel's Avatar
Car: 1992 firebird
Engine: stock 305
Transmission: stock
Axle/Gears: stock
will it fit
i have a 92 firebird w/ 305 auto. can get a 86 camaro w/305 5-speed. i want to swap the 5-speed to my firebird. is it a direct swap. thanks.
Old Dec 17, 2007 | 10:21 PM
KrisW's Avatar
Car: 88 V6 'bird/89TBI bird/85 T/A
Engine: 2.8/TBI/TPI
Transmission: V8 T-5/700R4 x2
Axle/Gears: 3.42 open/2.73 open/ 3.27 9 bolt
Re: will it fit
Everything except the flywheel. You will need an 87 or newer flywheel for the one piece rear main seal engine.
Other than that, you're golden.
Old Dec 17, 2007 | 10:33 PM
84redta's Avatar
Car: 80 SE/TTA;88 T/A GTA;86 T/A
Engine: 4.9L Turbo; LT1; empty
Transmission: TH350; T56; empty
Axle/Gears: 3:23 disk; 4:10 disk ; 3.42 disk
Re: will it fit
another thing to think of...in '88 i believe they had a second generation of t-5 transmissions, they had better internals for the most part. up to you, but you may want to look for a newer 5 speed manual tranny. like i said up to you and your budget.
but yes as stated above thats all you should need. It's good to get a donor car thought so you have something to pick from as you'll need the entire hydraulic system.
Fronzizzle
Feb 9, 2017 09:31 AM
New2Chevy
Sep 28, 2015 12:35 AM
armybyrd
Carburetors
25
Sep 13, 2015 01:49 PM
BOOT77
Sep 5, 2015 03:55 PM
Formula_88AE
Sep 3, 2015 01:47 PM
