Posi Problems...
Old Dec 21, 2007 | 12:43 AM
Bullydawg's Avatar
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
Posi Problems...
I have an 88 Firebird formula 350 and the Posi traction has been acting up. No noises, runs smooth and everything. But when I punched it only one wheel spun. Same with powerbraking, only one wheel spins. What is going on?
Old Dec 21, 2007 | 07:35 AM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
Re: Posi Problems...
Your Limited Slip rear is shot from too many burnouts and powerbraking starts.
Old Dec 21, 2007 | 10:31 AM
Pat Hall's Avatar
Yep, you got the infamous and all too common, 9 bolt posi problem. If it only recently started to slip, you might be able to fix it by shimming the clutch cones. There's a write up on how to do this in the tech articles section here.
Old Dec 21, 2007 | 11:04 AM
Bullydawg's Avatar
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
Could I just upgrade gears? If so, what are my options?
Also, the wheels switch off. Sometimes the drivers side spins, and sometimes the passenger wheel spins.
Old Dec 22, 2007 | 03:52 PM
antoine's Avatar
Car: 1988 camaro z28,1997 camaro lt1
Engine: 355 afr 195 heads,tpis big mouth
Transmission: 700r-4 built by me 3-4 z pack
put some gm posi additive
KO1
16
Oct 15, 2015 05:00 PM
92projectcamaro
Sep 29, 2015 07:07 PM
