TH350 or 700r4 tranny?
Car: 1990 T-Top Camaro RS
Engine: engineless
Transmission: Trannyless
Axle/Gears: 10 bolt/3.08. soon to be axleless
im looking to replace my warn out T-5 tranny.
since im doing an engine build and im hoping the engine will put out somewhere 400+hp.
i read afew articals about the TH350 and they seem to be really good. i found a kit for $1099 has a 400hp rating. comes with Tq converter. and i believe it came with a trans break. but the Tq conver was way to small, 1400,
anyways i havnt checked into the 700r4 trans yet.
since i heard really good sutff about the TH350. but now i see alot of people are running a 700r4. so ill be checking out prices.
my question is. is there a difference between the 2?
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
Re: TH350 or 700r4 tranny?
well you have a few things to consider here
th350 will be the same length as the t5 if it is the truck 9" tailshaft version, so that you dont have to find another driveshaftlength
you will need torque arm mount bracket from summit etc to mount a th350 in
700r4 will need to have the third gen f body tailshaft housing and 700r4 mount bracket and mount to be put under a third gen f body
700r4 takes more $ to build to make as reliable as a th350 at a certain engine hp strenth requirement
especially the pre-87 ones
if anything at least avoid the 82 83 84 700r4's
87-92 are the best and non ECM
good luck
good luck
Engine: engineless
hey thanks. yeah thats what i kinda wanted to know.
i dont want to replace the driveshaft.
ill probably just stick with the Th350
Car: 89 Firebird
Engine: 406 CI
Transmission: Pete K 700R4
Axle/Gears: 3:55
No one has mentioned the basics.
Turbo 350 was GM's medium duty 3 speed trans.
700r4/4l60 was GM's medium duty 4 speed trans.
4th is overdrive.
4th is overdrive.
Car: 92 Camaro
Engine: Dart SHP 406 HSR, LE heads
Transmission: Performabuilt Level 2, Vig 3200
Axle/Gears: S60 373
I just went through this debate not too long ago. I calculated everything and the th350 came out like 300 bucks cheaper. Alot of places want a th350 core and if you dont have it they want an additional 200 bucks. But I found a 700R4 that has a warranty for one full year on performabuilt no matter if I race it everyday or drive it like a grandma. I'd check out probuilt and performabuilt.
TinnMann2
Canadian Region
16
Jun 18, 2017 05:10 PM
[CA] 700R4 trans & parts
6998poncho
Sep 25, 2015 02:56 PM
