Rearend gears
Old Dec 21, 2007 | 11:13 AM
Fastcar92's Avatar
Car: 91 RS Camaro
Transmission: 5 Speed
Axle/Gears: 3:08
Rearend gears
I've put a 300 hp. 350 motor in my 91RS camaro,5 speed the stock gears are 3.08s what is a good gear ratio for freeway and regular driving? with these stock gears I wind out to fast.
Old Dec 21, 2007 | 11:40 AM
MrBrooks's Avatar
Car: '92 RS
Engine: 357ci
Transmission: G-Force t-5
Axle/Gears: 4.10 10bolt mini spool
Re: Rearend gears
What are you calling wound out? The red line on a factory thach no longer applies since you have a new motor. A 3.08 is an all around gear. Check your cam specs, generally as HP goes up so does you're rpm range. Most likely, "wound out" is now closer to 6000 than 4000.
Old Dec 21, 2007 | 12:36 PM
Fastcar92's Avatar
Car: 91 RS Camaro
Axle/Gears: 3:08
Re: Rearend gears
yea but I can go to 8000 or more, cant really know unless I get a different tack. the stock tack has been off ever since I bought the car. dont get me wrong it hauls but I just wanted to know if there was another gear ratio with a 5 speed to use or not. thank you!!
Old Dec 21, 2007 | 10:16 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Re: Rearend gears
No, a 300HP engine is never going to make it to 8000RPM, if we're talking SBC....
Anyway, 3.08's are fairly sleepy. 3.73's are a great gear set with a T5 overdrive tranny. Not as good on the freeway (mileage), but a lot more grunt taking off.
Old Dec 22, 2007 | 09:00 AM
Fastcar92's Avatar
Car: 91 RS Camaro
Axle/Gears: 3:08
Re: Rearend gears
well your wrong because I do hit 8000 rpms and a little bit more!
Old Dec 22, 2007 | 01:51 PM
Demon355's Avatar
Re: Rearend gears
How are you hitting 8k with 300hp? Whats been done to the motor?
Old Dec 22, 2007 | 02:11 PM
Sonix's Avatar
Car: 1982 Trans-Am
Re: Rearend gears
No, i'm not wrong, you're mistaken, and i'm right. I don't even feel the need to sugar-coat that assumption either. I didn't even ask what your engine was, what the combo was, etc etc etc. I won't even bother explaining why I can safely make this assumption, because anyone with any knowledge of Chevy SBC setups would know the answer.
Merry Christmas!
Old Dec 22, 2007 | 03:19 PM
C.M.Jones's Avatar
Car: 84 Camaro, 90Firebird, 87Transmaro
Engine: custom 5.7, 5.0 , 6.5 Turbo diesel
Transmission: 4spd, auto, auto
Axle/Gears: 2.77 posi
Re: Rearend gears
I hate fukin know-it-alls
yeah go with 3.73 or so gears
Old Dec 23, 2007 | 10:52 AM
Fastcar92's Avatar
Car: 91 RS Camaro
Axle/Gears: 3:08
Re: Rearend gears
well yes your wrong so face it' I blast out to 8000 rpms all the time.I guess you think you know it all. but you dont. sorry I had a 350 built for me bored, Vortec heads, cam,elelbrock headers,3in. cat back, a special chip programed for my specs. to this motor, and yes my tack hits 8000rpms. edelbrock intake. if you think you know what your talking about explain to me why my tack hits 8000+. smartey pants???????????
Old Dec 23, 2007 | 11:51 AM
RazinCayne's Avatar
Car: 92 Z28 / 66 Biscayne
Engine: 355 / 427
Transmission: T5 / M22
Axle/Gears: 3.42 Posi / 3.73 Posi
Re: Rearend gears
There you go...You said it right there. Go get a better tach and then come back and tell us you twist that 300 horse to 8 grand. You Sir, are old enough to know better than that.
Old Dec 23, 2007 | 06:36 PM
Sonix's Avatar
Car: 1982 Trans-Am
Re: Rearend gears
Yea, Razincayne (and all other sane members on here) understand this, and can help you fill in the blanks.
Your tach is wrong, a very common problem in these cars, or your aftermarket tach is wrong, either way...
It sounds like you really have no idea what's even in your engine, a "custom chip" means all of... 'diddley' as they say. You don't have enough cam to hit 8000RPM, or the right valve train or rotating assembly.
Smartey pants. I like that. My pants are smarter than you eh?
Old Dec 23, 2007 | 06:46 PM
joshh44's Avatar
Car: 1990 T-Top Camaro RS
Engine: engineless
Transmission: Trannyless
Axle/Gears: 10 bolt/3.08. soon to be axleless
Re: Rearend gears
if it is possible to hit 8000rpms. and doing it alot. that engine will soon die. and it seems like its coming up quick since you said your making it rev that high alot.
but i say get higher gears. i got 3.08s on mine. there great on the highway. i would look somewhere inbetween 3.08 and 3.75.
Old Dec 24, 2007 | 11:44 AM
91greenbird's Avatar
Car: 2012 Ram express
Engine: 5.7 hemi
Transmission: auto
Axle/Gears: 3.55
Re: Rearend gears
id say 4.56's so you can get to your 8,000rpm redline sooner
Old Dec 24, 2007 | 11:57 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
Re: Rearend gears
in for the subscription lol.
Old Dec 24, 2007 | 12:09 PM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
Re: Rearend gears
I am not sure what exactly is going on in here, but I want my new motor to spin to 8K.
Old Dec 24, 2007 | 09:55 PM
vincode8's Avatar
Car: 84 Z28
Engine: L69HO
Axle/Gears: 3:73
Re: Rearend gears
Was your car originally a V6 car? Or is your guage cluster from a V6?.....That would certainly cause a problem in your RPM readings. Whats the factory Redline on your in dash tach? This will tell us if this is the problem......also mathamatically speaking(although I'm not a math wizard) 8000rpm+, with 3.08 gears & 5 speed w/ factory size tire would give you one hell of a land speed record for a 3G F-body!!!!!!!!!!!
db057
Apr 28, 2019 07:45 AM
88rscamar0
Sep 23, 2015 09:08 PM
amcnellis
Sep 16, 2015 04:16 PM
Stroopwafel
Sep 11, 2015 06:38 AM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
