cross member
cross member
Not sure of the model I think 82,83, or 84 cross member I have is to short is all 82-92 cross members the same length mine is about 2inches to short is V-8 and V-6 the same also, it is T-Top if that matters.
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: cross member
iirc, the early 82,83,84 cars with the th200r4 had a different crossmember
Car: 84 Trans Am
Engine: 383
Transmission: Tremec TKO
Axle/Gears: 10 bolt 3.73 lsd
Re: cross member
the 82 - 83 cars were set up for the th200C 3spd auto or the man. 4spd. 84 saw the different length cm set up for the th700r4 or the man. t5
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: cross member
Along with the aforementioned cross member, you'll note that there are three others (which will all fit):
https://www.thirdgen.org/forums/hist...ss-member.html
JamesC
JamesC
LT1Formula
Oct 8, 2015 08:34 PM
