4th gen rear end in a 3rd gen??????
Old Dec 25, 2007 | 01:22 AM
SeaBeeCamaro's Avatar
Car: 1986 Camaro
Engine: 355 tpi
Transmission: t56
Axle/Gears: borg warner 3.73
With putting a 4th gen rear end in a 3rd would it be possible to get a set of rear wheels to make up the 2" wider rear end with a different backspacing. If i were to use the adapters on the fourth gen axle so that i can still use the 3rd gen wheels how much different would that be than running a 17in 4th gen camaro wheel.
Also what are the bolt spacing on the 4th gen rear ends compared to the 3rd gen.
Old Dec 25, 2007 | 09:50 AM
ssean92's Avatar
Car: sold
Re: 4th gen rear end in a 3rd gen??????
you need no spacer to run 4th gen wheels, you will need for the front though. and if you use the 3rd gen wheels on the rear they will stick out 2 inches
1992rs/ss
Jan 31, 2025 05:10 PM
hectre13
Dec 11, 2023 08:14 AM
1992rs/ss
16
Jan 28, 2016 09:58 PM
AkDrifted
Aug 17, 2015 07:45 PM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
