Combining rear ends
Old Dec 25, 2007 | 03:01 PM
wishihada3rdgen's Avatar
Combining rear ends
Hey everyone. I currently have 2 rear ends that I would like to combine into one. i have a disc 2.73 open 10 bolt from a 91 Z28 and a drum 3.73 posi 10 bolt from an 86 IROC. I would like to combine these 2 rear ends into a 3.73 posi rear with the disc brakes. Theres nothing that should stop me from combining these 2 rear ends and putting them into the 91 Z28 as far as I know but if there is I'd appreciate your help and knowledge. Thanks
Colin
Old Dec 25, 2007 | 04:15 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: Combining rear ends
Check to see how the backing plate for the drum brake is attached to the housing. Check to see how the caliper support is attached to the housing. I think they use different bolt patterns. This will prevent you from putting the disk brakes on the drum housing. If they are the same then it will be an easy swap.
Old Dec 25, 2007 | 08:32 PM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
91 rear= 28 spline axle shafts.
86 rear =26 spline axle shafts.
You are going to be mixing a lot of parts and end up using the older axle shafts which I think is regression just for a old Limited Slip & 3:73 gears.
Old Dec 25, 2007 | 08:36 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Read his post again. He already has the 28 spline posi in his diff. He want to put the disk brakes from the 86 onto the 91's diff which may be hard to do.
It's possible to take the posi, gears and axles out of the 91 and put them into the 86's disk brake housing. You'll just have to set up the gears again.
hectre13
Dec 11, 2023 08:14 AM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
Jlanz55
Aug 17, 2015 07:15 AM
BlackBoulder
Aug 11, 2015 11:15 PM
