Any stock size tranny pans that have a recessed drain plug?
Old Dec 30, 2007 | 04:49 PM
Firebat's Avatar
I know there is a 2 extra quart 4L60E pan you can get from a 2000 gmc truck that has a recessed drain plug. Any stock size pans have this recessed plug? Or should I just go with an aftermarket stock size pan with a normal drain plug because having a recessed plug shouldn't be needed for a stock sized pan?
I don't think there is a point in having 2 extra quarts in the car when I already have a trans cooler. Its just extra weight added to the car then, right? Also, I plan on lowering the car also in the future, 1 or 2 inches, so ground clearance might be an issue on the street with a deeper pan.
Old Dec 30, 2007 | 08:22 PM
87zjeff's Avatar
Axle/Gears: '01 3.42 10 bolt
Re: Any stock size tranny pans that have a recessed drain plug?
just buy a drain plug kit and install it in the side of your current pan.
NinjaNife
Aug 23, 2015 11:49 AM
Linson
Aug 21, 2015 02:12 PM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
knight72
Aug 10, 2015 09:32 PM
