Rear end/gear Ideas??
Car: 1987 Iroc-z
Engine: Swapped into a 350TPI
Transmission: T-56 Six Speed
Axle/Gears: Moser 12 Bolt 3:42 Gears
In my 87 iroc i have a 700r-4 with the 3:24 limited slip gears. There are no problems with the rear end but its time for an upgrade....I like the gearing as it is now( ABOUT rpm's @ 2700 at 80mph) what would a 3:73 gear to do my car at higher speeds?? Anyone ever do the Powertracs locker??? Please shoot some ideas fo what was done to your rides.....
Re: Rear end/gear Ideas??
3.73 is usually too much for a TPI car. A shorter gear(numerically higher) promotes power at higher rpm, which your motor does not have. 3.42 seems to be viewed as the best all-around performance gear for a street TPI car. - there are calculators on this forum to figure rpm vs gear ratio, do a search. FYI a 700r4 has a .70 OD(4th gear) ratio.
Stay away from any form of a locker with a 10-bolt. Lockers have a way of breaking c-clip axles and sending them out of the car around corners.
If you do indeed have 3.23's, then you have a 10-bolt, not the stonger/hard to find anything for 9-bolt.
Car: 1987 Iroc-z
Awesome-thanks!!
I'd like to stay with the 10bolt. Mabey just a freshen-up of the gears(just replacement of the gears/axles/seals) See just like any of us I don't want to replace any thing and have "replacment remorse" and living with a set-up I hate
. Thanks again for the imput
. Thanks again for the imput Re: Rear end/gear Ideas??
Awesome-thanks!!
Car: 1987 Iroc-z
Ya know...thank you-I usually stick to that motto "if it ain't broke-don't fix it" I figured upgrade....why not, but the more stories I hear...the more things I see/hear going wrong than right.
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
i wish i had your rear axle
i have a crap 2.73 one
i really think you should stickwith what you have
theres no real reason to change away from what you have already
no good reason i can think of
