rear end swap for a rear disc "upgrade" on convertible
I recently bought a 89 Iroc convertible. As you know the rear disc were not an option. Ive come across a GT4 rear end from a 84 trans am with posi, 3.73, and disc. My question is will this work without mods or gear changes and am I wasting my time with this "upgrade"? Thanks for any insight, Gregor.
Car: 1992 Firebird
Transmission: 700R4 with B&M shift kit
Axle/Gears: 3.23 zexel 4th gen
Re: rear end swap for a rear disc "upgrade" on convertible
Typically when you go from drum brakes to disc brakes you need to change the hydraulic pressure being fed to the discs because of the larger pistons in the caliper. The best way to do this is with a proportioning valve. There is a tech article here on how to install one and they go for around $40 on ebay.
Car: I race:86' I-roc Z
Engine: 350 bored 30 over (355)
Transmission: th400 w/B & M ratching shifter
Axle/Gears: has a 10bolt (for now,will change)
I have an 86' I -roc Z, it's a t-top. my car currently right now has disc up front and drums in rear. I'm gonna switch that 10bolt out w/a 9bolt out of a Trans Am. So, my car too will let alone have a stronger,better built rear,but also have 4 disc stopping power.The husband and I plan on upgrading the brake booster,the porportioning valve and break fluid reservoir, to accomadate for the added disc braking power. hope this helps and good luck.
kelly
kelly
Car: 92 WS6 Trans am convertible
Engine: ls 6.2
Transmission: 4l80
Axle/Gears: 2.73's
i have 92 ws6 ta vert and want to put rear disc and postitve i now it have the limit slip on now
Car: 91 Camaro RS
Engine: 305 TBI
Transmission: t5
Axle/Gears: 3.08:1
Sine i'm doing a open diff/drum to posi/disc swap, i was curious exactly what years fit how. 82-92 will all bolt up the same way and are the same width, but the 93 and up rear ends are slightly wider but will bolt up no problem anyway? the only things to really concider are the gear ratios and brake conversions right? thanks
Car: 92 T/A VERT
Engine: LB9
Transmission: AUTO
Axle/Gears: 7.5 / 3.42's
Correct, just don't use the 85-89 rear discs. They suck.....bad. The drums work about 100% better.
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
https://www.thirdgen.org/forums/faq-...iscs-89-a.html
Camaro067,
Adding your car's info (make, model, year, etc.) to your profile will make answering your questions easier.
JamesC
Engine: ls 6.2
Transmission: 4l80
Axle/Gears: 2.73's
I've heard that many times on this board. My personal experience with that set-up (82-88 Delco-Moraine calipers with 10.5" rotors), with the "fit kit" in place, was positive. However, the 89-92 PBR's are preferable. Here's a how-to to upgrade to them from Delco-Moraine's:
Posi = limited slip.
Camaro067,
JamesC
Camaro067,
JamesC
hectre13
Dec 11, 2023 08:14 AM
sailtexas186548
Jan 19, 2016 12:21 PM
novaderrik
Aug 10, 2015 12:44 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
