T-5 tranny. is it broken?
Old Jan 3, 2008 | 06:44 PM
mikeye90's Avatar
Car: 1992 Firebird
Engine: L03 : \
Axle/Gears: 10 bolt
Tonight i was driving my manual 1992 firebird, and when shifting into third at a high RPM, i heard a loud clank and now my shifter feels loose. everything runs fine but in general the shifting handle seems to have more room, it just feels looser, not as tight uncompromisingly hard to shift (as it was at times).
Is something broken? should i get this checked out? thanks
i believe its a t5 tranny.
Old Jan 4, 2008 | 12:53 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Re: T-5 tranny. is it broken?
If the tranny still shifts to each gear fine, with no noise, then you're ok. You probably just broke the tranny mount. Get under the car and look.
Old Jan 7, 2008 | 05:53 AM
mikeye90's Avatar
Car: 1992 Firebird
Engine: L03 : \
Axle/Gears: 10 bolt
Thanks man.
Old Jan 7, 2008 | 06:30 PM
mike_4_49ers's Avatar
yep. probably mount. the last two camaros i've had both got the 'clunk' right under the armrest. it might be hard to tell if the mount is broke while the weight of the tranny is on it. if you have to, you can put a jack under the tranny and drop the brace. the mount will probably just fall apart
Old Jan 7, 2008 | 08:27 PM
383backinblack's Avatar
Car: '91 Camaro RS
Engine: F1R Procharged 383
Transmission: Tremec 600
Axle/Gears: moser 12 bolt, 4.11's 33 spline axl
lol, the answer is yes......t5's are broken even when they're brand new
Old Jan 8, 2008 | 12:11 PM
Shagwell's Avatar
Car: projects.......
aww, come on man, T5's are tough, especially in 3rd gear....
Old Jan 8, 2008 | 12:22 PM
Car: '91 Camaro RS
lol
Old Jan 8, 2008 | 03:02 PM
mikeye90's Avatar
Car: 1992 Firebird
Engine: L03 : \
Axle/Gears: 10 bolt
Thanks for the replies and... lol?
sheachopper
Jul 31, 2019 11:27 AM
apie2546
Oct 16, 2016 02:24 PM
no green
Jan 9, 2016 09:22 PM
Reid Fleming
Oct 10, 2015 09:56 PM
mfp189
Sep 27, 2015 09:25 AM
