Clutch wont engage...
Old Jan 6, 2008 | 11:47 AM
oxrabidus's Avatar
Car: 1989 Camaro RS
Engine: 2.8l v6
Transmission: 5 Speed Manual
Axle/Gears: Probably the stock 3.42
I have a v6 camaro with a 5 speed... I cant shift very well and it has a really loud grinding sound when I put it in reverse... just out of curiosity... is there any way to bleed the clutch sytem? because my father told me that sometimes when air gets in there it wont engage completely... if not then what do I need to replace?
Old Jan 6, 2008 | 06:14 PM
ttypecamaro's Avatar
Car: 09 Cobalt SS Sedan. 92 Z28 vert
Engine: 2.0T EFR6758; 5.0TT T3/T4 8psi
Transmission: F40; 700r4
Axle/Gears: 3.76 LSD; 3.23 posi
Re: Clutch wont engage...
you probably mean that the clutch won't DISengage. Reverse is not syncronized in the t5 transmssion. If you put it in first gear to stop the clutch disk from spinning before putting it in reverse it should solve your problem. Remember "first before reverse."
There is a bleeder screw on the slave cylinder where the line connects to it. Follow bleeding instructions in a repair manual.
Old Jan 6, 2008 | 07:57 PM
oxrabidus's Avatar
Car: 1989 Camaro RS
Engine: 2.8l v6
Yeah... sorry bout the typo... thank you for the info... I did do the first then reverse thing... still did the loud scrape sound... I am hoping its just a little bit of air and not the whole clutch and stuff... thanks.
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
meeklay812
Oct 1, 2015 03:46 PM
mfp189
Sep 27, 2015 09:25 AM
Night rider327
Sep 2, 2015 04:18 AM
