Not going into Overdrive?
Old Jan 6, 2008 | 01:57 PM
MP81's Avatar
Car: 2007 Cobalt LT
Engine: M62'd 2.2L L61
Transmission: 4T45E 4-speed Automatic
Axle/Gears: Stock
Hi, I have a 700-R4 behind my 305, and I just took her up on the freeway, and I'm pretty sure the trans wasn't kicking into 4th gear.
I was driving about 80 the entire way - at 3000-3500 RPM. That seems a bit high to be in overdrive.
Is this normal OD RPM (Don't think so...) and what could be causing the trans not to hit OD, if it is, in fact, not.
Old Jan 7, 2008 | 11:32 AM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
Re: Not going into Overdrive?
A quick check on the OD without high speed. At 40 mph you should have 1000 RPMs on the tach while in OD>
Prodigious
Nov 7, 2020 09:23 AM
1992Z28!
Nov 19, 2015 07:33 AM
mcfastestZ28
Oct 5, 2015 07:12 AM
wisemanz28
Sep 20, 2015 01:26 PM
84 TA NV
Sep 6, 2015 08:02 PM
