Anyone have any experience with Hydraulic TOB?
Old Jan 8, 2008 | 03:11 PM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Doing another project, and planning to use a hydraulic throwout bearing, such as
one form howe racing:
http://store.summitracing.com/partde...5&autoview=sku
Infact, thats what I'm going to use. But I can't help but wonder, all you folks doing T56 swaps why you wouldn't just run the howe TOB so you wouldn't need the lame pull-style T56 clutch setup.. I'm trying to cure the same problem on a ZF6.
-- Joe
Old Jan 11, 2008 | 09:23 AM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Re: Anyone have any experience with Hydraulic TOB?
TTT. Someone must have used one.
Old Jan 11, 2008 | 11:56 AM
KrisW's Avatar
Car: 88 V6 'bird/89TBI bird/85 T/A
Engine: 2.8/TBI/TPI
Transmission: V8 T-5/700R4 x2
Axle/Gears: 3.42 open/2.73 open/ 3.27 9 bolt
I've used the McLeod universal setup on custom stuff; I like it fine.
I am also wondering why everyone is suffering with this T56 thing. What gives? Why is no one using the hydraulic throw out bearing?
I first discovered them when doing Jeep transplants. They are great!
Old Jan 11, 2008 | 12:25 PM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
The mcLeod one is kinda big money, but a couple I know are running those.
The T56 swap seems to look more straight forward if you just use your stock clutch setup, and run a hydraulic TOB.
-- Joe
Old Jan 11, 2008 | 05:54 PM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
Axle/Gears: 3.54 R200 IRS
How is it more straight forward using a different bearing, requiring custom lines, hookup to the master cyl, using a 4th gen T56 with the correct hydraulics its a direct bolt in and go.
Might be good for someone who happens across a trans without the rest of the swap, or for those running a 2 piece rms engine. When using a 1 piece rms, all i see is that you lose .6" of disc surface area
Old Jan 11, 2008 | 08:59 PM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Tom, your being silly.
Here is the example: You have a perfectly good T5 setup, with an amazing clutch. your transmission explodes. You buy a T56 and bell housing on ebay. You buy a $160 hydraulic throwout bearing, and a $60 braided hose. You install, and call it a day.
OR
You buy the T56 and BH, you buy a new T56 flywheel, you spend hundreds on a T56 clutch thats pull style so it might grab behind your HP motor it might not. You buy the hydraulics, and than kick yourself in the pants for spending hundreds more.
-- Joe
Old Jan 11, 2008 | 10:15 PM
MrBrooks's Avatar
Car: '92 RS
Engine: 357ci
Transmission: G-Force t-5
Axle/Gears: 4.10 10bolt mini spool
Or......you could bolt one of these to the front of an lt1 t-56 and not change a damn thing but the trans.
http://cgi.ebay.com/ebaymotors/T56-T...QQcmdZViewItem
Old Jan 11, 2008 | 11:10 PM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
Right, but the majority of people going to a T56 dont already have an "amazing clutch" and the majority of T56's sold that still work are usually packaged with all of the parts and pieces, so you buy a clutch for the T56, which really isnt all that expensive.
OR
-- Joe
Old Jan 12, 2008 | 06:05 AM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Isn't that for the LS1 trans with the longer input shaft?
-- Joe
Maybe from your yard. Last I checked, every junkyard I talkd to a while back said they only have the trans and BH on the shelf.
-- Joe
Old Jan 12, 2008 | 12:49 PM
87zjeff's Avatar
Axle/Gears: '01 3.42 10 bolt
how does that throwout bearing you posted supposed to fit a LT1 t-56? the LT1 t-56 doesn't have the bolt hole on the front plate to keep the throwout bearing from spinning. it might work on the LS1 style but it already has a hydraulic throwout bearing.
Old Jan 12, 2008 | 02:06 PM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
You dont have to run that one, you can run the floating style one which doesn't bolt in.
-- Joe
Old Jan 12, 2008 | 03:52 PM
MrBrooks's Avatar
Car: '92 RS
Engine: 357ci
[quote=anesthes;3596858]Isn't that for the LS1 trans with the longer input shaft?
It's for a t-56. It can be put on any of them camaro, vette, viper, (gag)cobra.
If you are upgrading from a t-5 this is the way to go. IMO
If upgrading from auto then find a lt1 trans and run a 3rdgen clutch, bell, fly set up with this mount plate. Most of the time its better to build you own "kit" rather than buying one.
Old Jan 12, 2008 | 04:29 PM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
[QUOTE=MrBrooks;3597354]
Whats the length of the input shaft on a T56? You bolt that plate on, and are you going to need an extended pilot bearnig? Will the tranny sit too far back?
-- Joe
Old Jan 12, 2008 | 05:58 PM
racer J's Avatar
Car: 1992 Chevrolet RS Camaro
Engine: 305 TBI
Transmission: WC T5 conversion
Axle/Gears: Debatable . . .
They probably make a hydraulic T/O bearing for use on non LS1 T56s. I know they make one for a T5.
Old Jan 12, 2008 | 06:22 PM
iansane's Avatar
Car: '91 TA vert
Engine: turboLSx
I used a hydro TOB from http://www.weirhotrodproducts.com/ and it was a pretty trick piece. Custom bellhousing and TOB that bolted to where an lt1's fork pivot bolt would go. It was pricy as hell. I never could quite get clutch engagement correct. Never seemed like it was completely letting go.
Old Jan 13, 2008 | 08:59 AM
MrBrooks's Avatar
Car: '92 RS
Engine: 357ci
[quote=anesthes;3597394]
-- Joe
It REPLACES the mounting adapter on the front of ANY t-56 not bolts to it to make it longer.
Old Jan 13, 2008 | 09:05 AM
87zjeff's Avatar
[QUOTE=MrBrooks;3598128]
it can't replace the front plate of a t-56, it doesn't have the bearing pockets for the countershaft. it has to be bolted to the front of the t-56. it has to be for either the LS1 version or the LT1 version. those adaptor holes are for the t-5 bolt pattern. the vette is it's own monster. the viper and the cobra both have different splines requiring a special clutch AND yoke not to mention the differences in input shaft length.
Old Jan 13, 2008 | 11:50 AM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
[QUOTE=87zjeff;3598132]
Thats kinda what I was getting at.
-- Joe
Old Jan 13, 2008 | 10:17 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
I picked up one used from a guy who didn't need it anymore on his '80s camaro with a T-10, so I can use it with my T-10 (I hate my mechanical Z-bar).
The setup is in my garage waiting to be installed. I'm not sure how i'll make up a custom bracket so it works right. I know our setups are different, but be sure to post how you set yours up, if there's any 'tweaks' or custom brackets needed.
Bohemian
Aftermarket Product Review
Nov 25, 2015 09:38 PM
91 SrS
Oct 7, 2015 04:32 PM
jaridjohn
Oct 5, 2015 07:01 AM
mfp189
Sep 27, 2015 09:25 AM
