frustrated TV cable/ switching to Dish!
Old Jan 13, 2008 | 12:04 AM
RlphKnndy496's Avatar
Car: 91 camaro RS
Engine: 305 TBI
Transmission: auto
Axle/Gears: 89 2.77 BW 9-bolt disc possi
Ok...I asked about my 91 shifting very fast...1-3 crossing the street...so someone pointed me to the tv...i read all/tons of tv adjustment threads...untill i got it...went out and tryed it...went for a test drive...1 to second is late 4k at 1\4 throttle...so now i'm reading more and the tv topic goes on for ever...but i can't find anything that tells me which way and how to soften it a bit?....when the D thing is released is the cable suposed to move/slide inn and out...could my d thing be stuck inn?...not locking cable in place..or??
Old Jan 13, 2008 | 03:36 PM
Car: 91 camaro RS
Engine: 305 TBI
Transmission: auto
Re: frustrated TV cable/ switching to Dish!
ok...my own reply...so others my learn...read,and read posts all night....looked under the hood in the sunlight....and i see now!!...with the throttle wide open....push in the D lock...and push the black plastic piece inn all the way...and release D lock...your done!!!....shifts perfect!!.....WOT is @ 4,500 RPM...just before redline....and at crusing/normal speed it maintains 1,500 rpm or so...and rises to 2,000 or so for every shift......you see before it went through every gear crossing the inersection....after adjusting tv the wrong way...it would not shift into second untill 4,000...at normal speeds....what i did wrong was when in pushed the D lock inn i was pushing the cable towards the firewall...not the black plastic piece with all the little groves like a zip-tye....thanks everyone
Old Jan 15, 2008 | 09:48 PM
klause83z28's Avatar
Car: 83 z28
Engine: boat anchor 305 (ex CFI)
Axle/Gears: 3.23 10 bolt
Hahahaha funny title for the thread. Adjusting the tv cable is really simple, and yet so many people don't have theirs adjusted properly. I had problems with mine, and it took me forever to get things adjusted correctly. All it took was a complete, accurate set of instructions and that was it.
Cheers!!
gta892000
Aug 11, 2019 11:16 AM
tglennon11
Sep 23, 2015 05:30 PM
neilb
Sep 15, 2015 05:06 PM
tglennon11
Interior Parts Wanted
Sep 11, 2015 10:25 PM
Randomtask2
Sep 10, 2015 08:37 AM
