Gear for street fun...and 200mph
Old Jan 14, 2008 | 02:49 PM
SuperchargedRS's Avatar
Car: Camaro of course
I was thinking a .5 t-56 with a massaged LSX engine and 3.72s in the rear would make a fun street car, but is there anyway of putting a 2 speed rear end in the back with 2. somethings so one could do something ridiculous (top speed wise) on one of those mad max long azz desert roads?
How much would one of those axles f your weight distro up?
One of the reasons I thought this might be a good idea compared to a over/under drive on the tailshaft (like gearvendors), is this would kick the weight of that auxiliary tranny out to the rear of the car.
Thanks,
-SuperchargedRS
Old Jan 14, 2008 | 03:06 PM
wrsjr's Avatar
Car: 1991 Camaro RS
Engine: 355
Axle/Gears: 10 bolt Richmond 3.73 posi w/ discs
Re: Gear for street fun...and 200mph
Thanks,
-SuperchargedRS
Those probably weight about 3 times as much as a stock axle if not more. You could look at putting a Winter/Franklin/Tiger quick change rear end that racers use. You would have to swap the gears manually but you would be able to at least have a ton of gear selection. I don't know how durable one would be on the street though.
Old Jan 14, 2008 | 03:41 PM
ryan91rs's Avatar
Car: 1991 RS, 84 El Camino conquista RIP
Engine: 5.0 (for now)
Transmission: 4L60
Axle/Gears: 2.xx torsen limited slip & 3.42 ope
that axle is a dually and looks like a military axle. you have to fight off the rock crawlers. doubt it could handle those speeds
Old Jan 14, 2008 | 08:34 PM
Gladstoneiroc's Avatar
Car: 91 Camaro RS
Engine: 5.0L TBI (ebl inside)
Axle/Gears: 3.42 lsd 10 bolt
Just did a quick calculation for you. Even with 3.73 and 26" tires, 6th gear would have a max speed of 250+ mph.
You'll have a lot of other things to deal with even before you even near 200.
Old Jan 15, 2008 | 06:49 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
theres a guy on NJFBOA who had a 2:73 rear behind his t56 for a while and the speed calculations were hilariously fast
Old Jan 15, 2008 | 07:12 PM
AutoRoc's Avatar
Engine: Vortec 4200 Inline 6 PT70 Turbo..
Transmission: 4L65E
You will want to make 600-700hp first and foremost. Pulling 6th gear is no joke, you need a LOT of power. 3.42's and 5th gear might get you there but it depends A LOT on how much or how little rpm you'll be revving. Goodluck!
Old Jan 15, 2008 | 09:49 PM
I dont remember the exact number but with the drag coefficient of our cars I though it was more like 500hp to make a hole in the air for 200.
Wonder how much a small hood scoop would effect the numbers (one about the size of the ones on the 03ish mustangs)
Old Jan 15, 2008 | 10:08 PM
iansane's Avatar
Car: '91 TA vert
Engine: turboLSx
Also have to thing about the room that's down there. Or as the case maybe, not down there. That thing would never fit unless it was sitting in the backseat.
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
Reddeath210
Oct 6, 2015 08:20 AM
86CamaroDan
Sep 29, 2015 10:08 PM
Chevy3shitty
Sep 1, 2015 02:10 AM
86White_T/A305
Aug 17, 2015 12:16 AM
