t56 m6
Old Jan 13, 2008 | 09:24 PM
TPI TERR's Avatar
On Probation
Car: 87 IROC-Z
Engine: LsX
Transmission: MN12 6speed
Axle/Gears: 3:42
t56 m6
im doing a t56 swap off the ls1's for my l98
i started off with a richmond set up mated with the stock t5 bellhousing and hydraulics flywheel and clutch and 4th gen driveshaft.. i have a new pilot bearing in the already the stock lookin ones
so far ill be swaping the pedals to the fourth gen ones for the new set up..
along with the slave cylinder on the firewall (hole is already there)
new clutch and flywheel
and hawks crossmember
didnt find any info regarding what starter to use.. or if i can even use the starter i am using right now. any info on this? thanks!!
Old Jan 13, 2008 | 10:15 PM
87zjeff's Avatar
Axle/Gears: '01 3.42 10 bolt
Re: t56 m6
if you are using the stock t-5 bell housing and flywheel, you should be able to use the factory starter.
Old Jan 14, 2008 | 08:16 PM
TPI TERR's Avatar
On Probation
Car: 87 IROC-Z
Engine: LsX
Axle/Gears: 3:42
Re: t56 m6
sounds good il be working on it tmrw morning.
Old Jan 16, 2008 | 09:03 PM
TPI TERR's Avatar
On Probation
Car: 87 IROC-Z
Engine: LsX
Axle/Gears: 3:42
Re: t56 m6
i used a ls2 style flywheel and clutch and the bolt pattern on the flywheel didnt match up to the crank..
MoJoe
Members Camaros
33
Feb 6, 2025 09:47 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
bigjay89gta
Oct 15, 2015 08:04 AM
meeklay812
Oct 1, 2015 03:46 PM
Vincent135
Sep 28, 2015 10:50 PM
