what gear do i have?
Old Jan 14, 2008 | 10:27 PM
alpine247's Avatar
Car: 1988 IROC-Z
Axle/Gears: 2.77 posi stock
ok i have an 88 iroc 350, the rear end is a 9bolt posi but i dont know what gear it is,the tag on the rearend is gone..
so anybody have any info??
Old Jan 15, 2008 | 01:29 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Re: what gear do i have?
You have two choices, either a 3.27 or a 2.77 ratio. The 2.77 is more common. What RPM are you at while driving down the freeway in 4th gear?
Old Jan 15, 2008 | 01:34 AM
tmviper's Avatar
i am going to tell you what i did to figure out my rear ratio. i too could not find any tags on my rear, so listen closely
1- mark the end of the driveshaft that goes to the rear, and mark a spot on the rear with chalk and make sure they line up.
2- mark the tire with chalk.
3- with the car in the air, spin the tire one full revolution. take note to how many times the driveshaft spins one full revolution. once my tire spun 360 degrees, my driveshaft had spun 3 turns, and about a quarter more, so i know that i have 3.23s, or 3.27s.
if it spins a little over 3, youve got 3.08s. 3 and a half, 3.42s, 3 and three quarters, 3.73s, a little over 4, 4.10/4.11s.
simple right?
Old Jan 15, 2008 | 09:48 AM
alpine247's Avatar
Car: 1988 IROC-Z
7grand haha tach is messed up so i have no clue on that either ...
simple right?
i give this a try
gta892000
Aug 11, 2019 11:16 AM
db057
Apr 28, 2019 07:45 AM
88rscamar0
Sep 23, 2015 09:08 PM
Stroopwafel
Sep 11, 2015 06:38 AM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
