Posi Question
Old Jan 15, 2008 | 05:18 PM
yaretheytaken's Avatar
Car: 92 RS
Engine: 350 Carb'd (almost TPI)
Transmission: 700R4 (soon a T-5)
Axle/Gears: 3.23's
Posi Question
Alright, so this kid I go to school with just bout a roller Camaro and he offered to sell me the rear end. The rear end is posi and has disc brakes. Both of those benefit me a lot because I have an open diff and rear drums. The only problem the kid says that the posi needs new clutch packs or something like that. I'm not very knowledgeable when it come to posi. I have been doing some research to try and enlighten myself and I have learned a lot about posi. I also read an article on TGO about shimming the diff. My question, assuming that the clutches are bad, can I replace the clutches? Would I need a new carrier? Would the shimming process fix the issue at hand? Also what price would be resonable for the rear end, all brake equipment is included. Thank in advance for the help.
Old Jan 15, 2008 | 05:25 PM
MrBrooks's Avatar
Car: '92 RS
Engine: 357ci
Transmission: G-Force t-5
Axle/Gears: 4.10 10bolt mini spool
Re: Posi Question
The DETROIT units are rebuildable. If someone has made the mistake of an AUBURN unit its toast---unrebuildable.
Old Jan 15, 2008 | 05:32 PM
Car: 92 RS
Axle/Gears: 3.23's
Re: Posi Question
How would I tell the difference between a Detroit or an Auburn unit? How much would parts to fix it cost?
Old Jan 18, 2008 | 03:01 PM
Car: 92 RS
Axle/Gears: 3.23's
Re: Posi Question
The parts car the kid picked up is a 86 Z28 I'm not sure what motor it came with all I know is that the rear is original and it is posi. With that being said, assuming the clutches are bad, is it fixable? How much would it cost to fix? I am going to go look at it Monday. I have an idea of what to look for but if anyone has suggestions on what I should look for input is appreciated. Thanks, John
Old Jan 19, 2008 | 12:06 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Re: Posi Question
It's an auburn. Stock was auburn, and non-rebuildable. He's trying to sucker you.
Old Jan 19, 2008 | 12:18 PM
ryan91rs's Avatar
Car: 1991 RS, 84 El Camino conquista RIP
Engine: 5.0 (for now)
Transmission: 4L60
Axle/Gears: 2.xx torsen limited slip & 3.42 ope
Re: Posi Question
i tore one apart before to see how it was built and it looked rebuildable. then again the spring perches were the only broken parts
Old Jan 19, 2008 | 12:28 PM
Sonix's Avatar
Car: 1982 Trans-Am
Re: Posi Question
Yea, now try to get new clutch packs for an Auburn
Old Jan 20, 2008 | 10:48 AM
Pat Hall's Avatar
Re: Posi Question
Count the bolts on the rear cover. Only the 9 bolt rears can be fixed by shimming, and even then, that only works if it's been slipping for a short amount of time. If it's a 10 bolt rear, then it has an Auburn, which is not rebuildable as the other guys stated. The only sure cure for a toasted 10 bolt posi is replacing it with a better, Eaton posi carrier, which will set you back $400-$500.
Old Jan 22, 2008 | 11:10 AM
Car: 92 RS
Axle/Gears: 3.23's
Re: Posi Question
Thanks for all the help. I was supposed to go look at it yesterday but the kid forgot and left town for the day. Hopefully I can take a look at it to see if it's 9 of 10 bolt. Do you guys think I'm better off just leaving this alone or is it worth it for the disc brakes?
Thanks, John
hectre13
Dec 11, 2023 08:14 AM
hectre13
Aug 26, 2015 08:17 AM
redmaroz
Aug 16, 2015 11:40 PM
mcgarnicle
Aug 12, 2015 04:58 PM
