speedometer gears?
Old Jan 16, 2008 | 05:24 PM
PAFORM350's Avatar
Car: 1992 Formula 350
Engine: 5.7 L98
speedometer gears?
Anyone have any ideas what speedo gears I would use to correct the speedometer in my 1992 Formula 350? It has 4.10 gears. Thanks.
I am using 26 X 10.5 MT ET Streets in the rear
Old Jan 16, 2008 | 06:09 PM
87zjeff's Avatar
Axle/Gears: '01 3.42 10 bolt
Re: speedometer gears?
bowtie overdrives has a good speedo calculator.
Old Jan 16, 2008 | 06:11 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
What transmission do you have?
Old Jan 16, 2008 | 08:32 PM
PAFORM350's Avatar
Engine: 5.7 L98
It's the one that came with the car. 700R4 ?
Old Jan 16, 2008 | 08:36 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
15 and 44 for a 700R4
7 and 22 for a T5 and aftermarket T56
Old Jan 17, 2008 | 03:02 AM
Pro Built Automatics's Avatar
With 4.10's, you will need an external adaptor, as 45 driven and 15 drive is far as the ratios go. You would need a 47 driven, if it were available.
db057
Apr 28, 2019 07:45 AM
88rscamar0
Sep 23, 2015 09:08 PM
TrevinE
Sep 14, 2015 03:20 PM
andy74
Sep 3, 2015 08:41 AM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
