I have no first gear, but all others
Old Jan 18, 2008 | 06:36 AM
Achoo's Avatar
I have a 1992 RS 305 with the 700r4. The car works fine and normal from bout 25-30mph on up but has no gut to it from start. When placed in "1" manually it still acts like it is put into "2". Any ideas on a diagnosis? I've never worked on an auto transmission so if it doesn't need to be replaced, will I be able to fix it myself without getting in over my head? Thanks for any help.
Old Jan 21, 2008 | 11:55 AM
BryOwnz's Avatar
Re: I have no first gear, but all others
check your linkage, it may not be allowing the car to go into 1st? does it do it when its in drive? when you take off how many shifts does it go through?
also check your fluid levels and even your trans filter, i dont know alot about them but i know low fluid levels and a clogged filter will make it do odd things...
Old Jan 21, 2008 | 12:17 PM
Achoo's Avatar
Thanks, i'll have to check it all out this weekend. As for shifts in drive, it's just 2. From second to drive, then drive to overdrive.
gta892000
Aug 11, 2019 11:16 AM
db057
Apr 28, 2019 07:45 AM
88rscamar0
Sep 23, 2015 09:08 PM
Stroopwafel
Sep 11, 2015 06:38 AM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
